Does anyone have the pin out for the older style Volkslogger plug that used
the 5 pin screw on plug assembly. The manual only refers to a colour code factory lead. Many thanks Martin Carolan |
X-no-archive: yes
In article , POP_Server=pop.clara.net writes Does anyone have the pin out for the older style Volkslogger plug that used the 5 pin screw on plug assembly. The manual only refers to a colour code factory lead. Many thanks Martin Carolan Yes. Go to http://www.spsys.demon.co.uk/download.htm#GCS and click on the 'Special Cable for Volkslogger' link. Tim Newport-Peace "Indecision is the Key to Flexibility." |
On the old style round connector for the Volkslogger the pin outs are as
follows: Pin 1 - Ground Pin 2 - +12V Pin 3 - Not used Pin 4 - NMEA Data Out Pin 5 - Data In to Volkslogger Harold Ennulat ENTEC "POP_Server=pop.clara.net" wrote in message ... Does anyone have the pin out for the older style Volkslogger plug that used the 5 pin screw on plug assembly. The manual only refers to a colour code factory lead. Many thanks Martin Carolan |
Volkslogger flight log problem | Bill Staley | Soaring | 1 | October 7th 03 03:26 PM |
VOLKSLOGGER & AERO PALM | Ray Lovinggood | Soaring | 1 | October 5th 03 01:30 AM |
Declaring a flight in WinPilot to the Volkslogger | JohnD | Soaring | 0 | October 1st 03 11:55 PM |
Volkslogger Calibration | Ray Lovinggood | Soaring | 5 | September 13th 03 04:56 PM |
Problem: Ground Speed Estimate with Volkslogger and WinPilot | RamyYanetz | Soaring | 3 | August 26th 03 03:06 PM |
