Discus B aileron sealing
Old March 17th 17, 12:53 AM posted to rec.aviation.soaring
Kurt[_3_]
Default Discus B aileron sealing
I have a Discus B with the mylar seals on the bottom of the ailerons. When I bought the ship, it had tape on the top gap, which bows up depending on the deflection of the surface. I re-read Dick Johnson's flight test and it appears that the tape could be eliminated. He sealed the push rods at the wing root. So, the question is, does the aileron hinge gap on the top of the wing need to be sealed if I have mylar on the bottom gap, and if I seal the push rods on the wing root? The gap is pretty large.
Thanks!
Old March 17th 17, 06:27 AM posted to rec.aviation.soaring
Ross[_3_]
I am rather certain that it was standard to seal top and bottom.
I have run a teflon tape over the top gap and then mylar over the top mainly because there was a recess for it in the wing.
Any gap that you can drive a horse and cart through should be sealed
Old March 17th 17, 06:48 AM posted to rec.aviation.soaring
krasw
Thanks!
If you get water on top of the wing, it runs down to unsealed aileron/wing gap and corrodes hinge pins. Lower seal makes sure all the water stays in the hinge line. Aerodynamically, it is probably unnecessary.
Old March 17th 17, 10:59 AM posted to rec.aviation.soaring
Thanks
Have the factory seal schedule for you. Need an e-mail
Aileron inboard edge sealing Piotr Jaszczuk Soaring 14 March 10th 16 11:41 PM
Ventus B, Discus ect aileron connecting rod/slide lube [email protected] Soaring 22 February 4th 15 05:52 PM
Discus Aileron Seals Peter F[_2_] Soaring 8 August 20th 13 05:07 PM
left aileron for Discus CS wanted [email protected] Soaring 0 September 28th 12 01:31 AM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
