Hi, we see lots of mylar gap seals and read lots of discussion of them. Does anyone know of an engineering study that quantifies their effect on sailplane wings or other wings? Nothing pops up quickly in Google. I'm wondering how much science there is to this practice.
I'm hoping for more than anecdotal comments. Saying that top racers all use them doesn't tell us much because so do almost everyone. |
Il giorno lunedì 12 giugno 2017 07:38:22 UTC+2, Bret Hess ha scritto:
Hi, we see lots of mylar gap seals and read lots of discussion of them. Does anyone know of an engineering study that quantifies their effect on sailplane wings or other wings? Nothing pops up quickly in Google. I'm wondering how much science there is to this practice. I'm hoping for more than anecdotal comments. Saying that top racers all use them doesn't tell us much because so do almost everyone. To put things simple (may be too simple): think how the wing works, lower pressure on the upper surface than on the below surface, if you open a hole the air pass-by Carlo |
On Monday, June 12, 2017 at 1:38:22 AM UTC-4, Bret Hess wrote:
Hi, we see lots of mylar gap seals and read lots of discussion of them. Does anyone know of an engineering study that quantifies their effect on sailplane wings or other wings? Nothing pops up quickly in Google. I'm wondering how much science there is to this practice. I'm hoping for more than anecdotal comments. Saying that top racers all use them doesn't tell us much because so do almost everyone. Look up any of Richard Johnson's flight tests before and after seals, especially the LS-4. Or any other modern sailplane. There was as much as a 5 point difference. |
Thanks. I read the two LS-4 articles, but the "after" wasn't conclusive: Different plane, different probe positions, and Dick doesn't make much of a conclusion on if the performance was better, or just measured to be better. Is there another one where he does the same plane with the only difference the mylar seals? |
A lot depends on the airfoil and condition of surfaces. For a 1-26 that needs paint, not much difference. On a modern airfoil with 90-95% laminar flow, it makes a bigger difference.
Most really need the internal seals, then various amounts of need for external Mylar seals. Keep in mind, I don't think they EVER hurt performance. |
![]() A lot depends on the airfoil and condition of surfaces. For a 1-26 that needs paint, not much difference. Disagree, a properly sealed 1-26 has almost 5 mph slower stall, and a crisper roll than one that is not sealed. Kevin 92, formerly 192 |
I totally understand about sealing a 1-26, I'm co-owner of 002 and have a lot of 1-26 hours (not as many as Ron Schwartz). Wing root seals (internal and external) as well as fabric aileron/rudder/elevator seals are needed. Mylar seals make little to no difference, that was my point.
Le lundi 12 juin 2017 07:38:22 UTC+2, Bret Hess a écritÂ*:
Hi, we see lots of mylar gap seals and read lots of discussion of them. Does anyone know of an engineering study that quantifies their effect on sailplane wings or other wings? Nothing pops up quickly in Google. I'm wondering how much science there is to this practice. I'm hoping for more than anecdotal comments. Saying that top racers all use them doesn't tell us much because so do almost everyone. There is quite a number of gliders which require the seals in place to be airworthy. Apart from the obvious loss of performance without seals, the air flow escaping through this area might induce flutter (which in turn will induce a loss of performance of 100%). Bert "TW" |
The air flow escaping through this area might induce flutter (which in turn will induce a loss of performance of 100%).
Bert "TW" Are you talking about the exterior mylar seals or the fabric "S" seals in the joint? Once the fabric seals are in place I don't think air escaping is the real issue, more of turbulence due to the dip in the sahpe, but I suppose that could aid flutter. |
On Monday, June 12, 2017 at 11:51:11 AM UTC-6, wrote:
The air flow escaping through this area might induce flutter (which in turn will induce a loss of performance of 100%). Bert "TW" Are you talking about the exterior mylar seals or the fabric "S" seals in the joint? Once the fabric seals are in place I don't think air escaping is the real issue, more of turbulence due to the dip in the sahpe, but I suppose that could aid flutter. I see now that some gliders don't have seals internal to the joint, and depend only on these exterior seals, so you're right about the flutter problem. |
Measuring the effectiveness of a sandblaster? | Michael Horowitz | Home Built | 17 | June 14th 09 12:50 PM |
Instructor Effectiveness | Ol Shy & Bashful | Piloting | 43 | September 21st 08 03:20 PM |
Ground effect effectiveness | Tony | General Aviation | 14 | January 10th 07 11:17 PM |
Ground effect effectiveness | Tony | Piloting | 20 | January 10th 07 11:17 PM |
Effectiveness/clarity of throat mic? | Gary G | General Aviation | 1 | October 11th 05 01:44 AM |
