Energy
Old August 1st 17, 02:28 PM posted to rec.aviation.soaring
Default Energy
Hi
I am looking for a text on total energy, netto and relative netto.
Specifically on why use one in particular in climb or cruise on my vario?
Which setting gives a better picture of the condition you are in?
Thank you
Gilles
Old August 1st 17, 02:59 PM posted to rec.aviation.soaring
Dan Marotta
Default Energy
I haven't read it on over 30 years, but check _Cross Country Soaring_ by
Helmut Reichman.
On 8/1/2017 7:28 AM, wrote:
Hi
Thank you
Gilles
Dan, 5J
Old August 1st 17, 03:37 PM posted to rec.aviation.soaring
Bruce Hoult
Default Energy
On Tuesday, August 1, 2017 at 4:28:47 PM UTC+3, wrote:
Hi
Thank you
It's just a theoretical progression of making the vario easier to interpret.
The question each vario answers:
basic: how fast are are we climbing or descending? (static pressure)
TE: how fast are we gaining or losing energy? (add in airspeed)
netto: how fast is the air mass rising or sinking? (add in the glider's polar)
rel netto: how fast would we climb if we circled? (add in circling polar)
Old August 1st 17, 04:55 PM posted to rec.aviation.soaring
Scott Williams
Default Energy
On Tuesday, August 1, 2017 at 8:28:47 AM UTC-5, wrote:
Hi
Thank you
Gilles
I agree with Dan,
Herr Reichman,
Secrets of the Universe!
Good Lift,
Scott.
Old August 1st 17, 05:43 PM posted to rec.aviation.soaring
Alex[_6_]
Default Energy
Use total energy for climb and relative netto for cruise. Here is why:
A total energy vario is difficult to interpret at high speeds. If you go fast it will show plenty of sink because your polar sink increases with speed.. If you pass through a weak thermal it will be masked by all the polar sink in your vario reading.
The netto vario will solve the issue by removing your polar sink for speed you are currently flying. In dead air the Netto vario should read zero, no matter how fast you fly. A netto vario can be a bit awkward because a positive reading does not necessarily mean you are climbing - it just means the air is going up.
A relative netto solves exactly this problem. It takes the netto value and inserts your polar sink for your thermalling polar. In dead air it should be reading around minus 0,6m/s for your average high performance glider.
While thermalling, relative and total energy should be reading the same value. The whole point of netto and relative netto is getting good indicator of climb and sink at cruising speeds.
Whether you prefer netto or relative netto is a matter of taste. A netto vario will make it easier to read minute energy lines at a glance whereas relative netto is closer to what you are accustomed to.
Old August 1st 17, 05:53 PM posted to rec.aviation.soaring
Default Energy
Le mardi 1 août 2017 09:28:47 UTC-4, a écritÂ*:
Hi
Thank you
Gilles
Thank you all
Gilles
Micro-wind energy Stephen Michalik[_2_] Soaring 12 February 8th 14 05:44 PM
Way to go Joe! (energy advances) Duane Ritter Piloting 0 March 26th 11 09:41 PM
Total energy probe orientation? John Bojack[_2_] Soaring 4 June 5th 09 02:33 PM
Energy management Ian Cant Soaring 11 February 18th 07 10:14 PM
varios not using a total energy probe Robert Soaring 20 April 25th 04 11:24 PM
