Sustainer engine run
Old August 9th 17, 02:55 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Sustainer engine run
Just curious, how long are the guys with solo 2350 sustainer engines running their engines before they depart on XC flights? I have been running the engine for about 30 seconds but I have no idea how long it should to run to be fully lub'ed and kept in good running condition.
Old August 9th 17, 05:17 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
2 minutes on every 3rd flight.
19+ years, 1700 flight hours, and 10 engine hours in this period.
Bob
On Tue, 8 Aug 2017 18:55:11 -0700 (PDT), "Jonathan St. Cloud"
This email has been checked for viruses by AVG.
http://www.avg.com
Old August 9th 17, 08:26 AM posted to rec.aviation.soaring
Jonathon May
Bob
engines
been
long it
http://www.avg.com
We run the motor in our duo for 30seconds to mark the trace.
There are some people will accuse you of using it on task if there is
no obvious mark.
Old August 9th 17, 10:02 AM posted to rec.aviation.soaring
Z Goudie[_2_]
runnin=
to=
30seconds. The main reason being to make sure it's probably going to start
when I need it! If I forget to do that it concentrates the mind somewhat
if I get low later.
Old August 9th 17, 11:34 AM posted to rec.aviation.soaring
30-60 seconds on EVERY flight before going beyond gliding distance of the airport. Mostly to give you some assurance that it is likely to start if called upon later that day. A short run will also make sure you have the fuel valve open (I always leave my valve open all flight), it will also remove any vapor bubbles in the fuel lines, and if it's cool, it'll warm up the motor a bit which helps it start a bit faster later.
Old August 9th 17, 08:29 PM posted to rec.aviation.soaring
Bob Gibbons[_2_]
For what its worth, before every flight I pressurize my removable fuel
tank with a pump bulb (standard blood pressure bulb). Primary purpose
is to check for any fuel leaks in the plumbing. This has revealed
loose connections on several instances over the years. Second step is
to then depress the injector diaphragm (rear injector) to remove any
air bubbles in the fuel line.
My 1997 Ventus cT does not have a boost pump.
Bob
On Wed, 9 Aug 2017 03:34:52 -0700 (PDT),
http://www.avg.com
Self-launch v Sustainer Duster Soaring 45 November 9th 16 05:36 PM
Self Launching/Sustainer engine reserve [email protected] Soaring 2 July 29th 15 03:31 PM
ASG-29E vs. JS-1Jet Sustainer Gerry Simpson Soaring 52 July 8th 15 01:29 PM
Sustainer engine ignition noise (Solo2350) Per Soaring 8 January 4th 07 05:56 AM
DG goes the sustainer option. Paul Soaring 25 June 4th 04 12:16 AM
