Winching-Cable danger
Old March 23rd 04, 03:32 PM
Andy Davey
Default Winching-Cable danger
When I drove winches for the air cadets, we often had
problems with bits of cable flying about in the cab.
On the old Eagle winches there are 2 drums, one of
which is directly in front of the driver. If the cable
'threw a loop' then it would rattle against the totally
inadequate metal grille that was resting(not bolted)
over the drum. Occasionally the whole grille would
leap out at you! Some winches had perspex sheets fitted
to the grille, but every one I saw was damaged-usually
with a few fragments left clinging to the bolts that
held the perspex on.
No-one ever got injured as far as I'm aware, but it
was more luck than judgement.
It certainly scared the s*&% out of you when it happened!
Winching - Cable danger. W.J. \(Bill\) Dean \(U.K.\). Soaring 9 March 27th 04 11:51 PM
cable splicing(w/o ferrules) Andy Davey Soaring 2 March 19th 04 12:49 PM
rudder cable question Bob Loer Home Built 7 November 26th 03 08:34 AM
Rudder cable - was The Little Wheel in Back BD5ER Home Built 9 September 11th 03 04:14 PM
Winch cable Bill Daniels Soaring 5 August 24th 03 11:13 PM
