Plastic razor blades for removing tape/glue residue
Old September 30th 17, 08:27 PM posted to rec.aviation.soaring
Default Plastic razor blades for removing tape/glue residue
Another thread mentioned using a credit card, but some time ago, I discovered these:
https://smile.amazon.com/Single-Edge...c+razor+blades
or these:
https://smile.amazon.com/7MO-Scraper...c+razor+blades
They wear out pretty quick, but won't catch the finish.
-Tom
Old October 1st 17, 02:15 AM posted to rec.aviation.soaring
Waveguru
Have you tried shaving with them Tom?
Boggs
Old October 4th 17, 11:27 AM posted to rec.aviation.soaring
Philip van de Donk
or these:
-Tom
Why not use White Spirit? Works like a charm with some paper towels:
https://en.wikipedia.org/wiki/White_spirit
Old October 4th 17, 02:35 PM posted to rec.aviation.soaring
What in the world is "White Spirit?"
Turpentine?
White gas?
100% ethanol?
Naphtha?
Toluene?
Methylcyclohexane?
Acetone?
Old October 4th 17, 02:51 PM posted to rec.aviation.soaring
"White Spirit" is probably the trade name for what we cynically call any of the really hazardous solvents. You know, like "Methyl Deathyl Ethyl."
Favorite ingredient in Walter White's blue meth.
Old October 4th 17, 02:52 PM posted to rec.aviation.soaring
Paul Agnew
Mineral spirits - White Spirits
Old October 4th 17, 02:54 PM posted to rec.aviation.soaring
Paul Agnew
This link explains what White Spirits are with multiple references.
http://bfy.tw/EHtI
PA
Old October 4th 17, 02:56 PM posted to rec.aviation.soaring
Tango Whisky
Le mercredi 4 octobre 2017 15:35:33 UTC+2, a écritÂ*:
Turpentine?
White gas?
100% ethanol?
Naphtha?
Toluene?
Methylcyclohexane?
Acetone?
Trade name for Turpentine in the Old World.
Old October 4th 17, 05:22 PM posted to rec.aviation.soaring
Ross[_3_]
A slow rotating rubber disc in a drill works wonders. After that a quick wipe and you are ready to go.
Never need worry about losing the skin off your fingers either
Old October 4th 17, 10:05 PM posted to rec.aviation.soaring
I have "rubbed off" adhesive with a thumb before.
OK for a few feet, sucks for meters.
A possible alternative? Do a search for "auto pinstripe removal", I have 2 rubber disc's used in an electric drill that work wonders.
I will guess the colder the adhesive the better the results.
I took off about 20' of 16yo pinstripe on a car in less than 30 minutes. No harm to auto paint, a quick machine compound made it invisible other than the difference in paint color due to UV masking.
Saved some thumb skin.
May try it at "Skunkworks" soon......
Removing oxidation from Cobra trailer trim rubber and plastic fenders Dave Nadler Soaring 11 September 25th 17 05:57 PM
Removing Old Tape Kevin Christner Soaring 5 March 27th 12 11:07 PM
Removing tape residue from canopy BravoNiner Soaring 15 March 23rd 09 07:23 AM
removing old, dried, masking tape Michael Horowitz Home Built 9 January 4th 07 05:54 PM
Model Building (but not with plastic and glue) [email protected] Soaring 7 March 3rd 05 04:01 AM
