Transceiver Troubleshooting Guide
Old November 1st 17, 02:43 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
Default Transceiver Troubleshooting Guide
I get one question a lot, to wit, "My radio isn't working! WHAT DO I DO NOW????"
So I put together a simple "things to look for" guide to troubleshooting your transceiver woes.
Find it here http://aviation.derosaweb.net/presentations/
Let me know if you have things that could enhance this document.
Thanks, John Ω
Old November 5th 17, 05:41 AM posted to rec.aviation.soaring
2G
On Wednesday, November 1, 2017 at 7:43:56 AM UTC-7, OHM Ω http://aviation.derosaweb.net wrote:
Thanks, John Ω
Most electrical problems can be traced to a connector (which may be inside the radio), followed by cabling problems. This becomes exaggerated with age.. I very recently found a solar panel problem that was a broken connector pin). Get a can of electrical contact cleaner and magnifying glass. Look at EVERY soldered connection very carefully (a broken wire going to that solder joint can look very much like it is connected).
The next thing to go are capacitors; the electrolyte in polarized capacitors dries up and they lose their capacitance. This goes especially for aluminum electrolytics (the can shaped ones). Fixing that, however, takes more soldering skills than you may have.
Tom
Old November 6th 17, 11:10 PM posted to rec.aviation.soaring
Inspecting the connectors is the most important item on everyone's list.
But getting inside a radio is not for the faint of heart and I just recommend "send it into a repair shop". The most I have ever done was replacing the fusable link inside a Microaire radio (reversed battery) and that was touch and go. These things are just too compact/complex unless you are REALLY good at this.
About capacitors. The most common aliment seems to be the dielectric expanding due to heat and poor manufacturing, which changes the capacitance. At least you can tell right away because the silver cap has bulged, sometimes cracked. I have repaired many (non aviation) items by just replacing caps..
Old November 7th 17, 02:33 AM posted to rec.aviation.soaring
2G
On Monday, November 6, 2017 at 3:10:45 PM UTC-8, OHM Ω http://aviation.derosaweb.net wrote:
On has to assess their own abilities when attempting these type of repairs. Just getting the back cover off of my laptop can be daunting. Replacing capacitors requires the proper temperature controlled soldering gear (not one of those irons with the AC plug wire coming out the end!) and de-soldering gear. If you haven't done this before best to send it off to a repair shop..
Tom
Vertex VXA-150 troubleshooting JS Soaring 2 June 5th 09 12:17 AM
troubleshooting com's transmission jan olieslagers[_2_] Home Built 2 April 13th 09 02:39 AM
Oil Pressure Gauge Troubleshooting Kyle Boatright Home Built 10 October 19th 05 04:04 AM
Valcom 760 Transceiver Troubleshooting David Johnson Home Built 6 July 8th 04 03:59 AM
Transponder/Encoder troubleshooting [email protected] Owning 6 August 27th 03 02:50 AM
