Solar Trailer Vent?
Old December 28th 17, 03:54 PM posted to rec.aviation.soaring
Daniel Sazhin[_2_]
Default Solar Trailer Vent?
Hey Guys,
Aero Club Albatross is in the middle of restoring its LS3 trailer and we're looking for a solar powered vent. Any suggestions?
Thanks a million,
Daniel
Old December 28th 17, 03:57 PM posted to rec.aviation.soaring
http://www.discountmarinesupplies.co...0aAr1rEALw_wcB
Old December 28th 17, 04:08 PM posted to rec.aviation.soaring
Retting
1000 ft3 in 15 kt wind!? Well, ah yeh.....I put two of these on mine....I like the low drag , discount for two.
https://www.google.com/search?q=Ship...dTo6a_o8-gsPM:
Sorry, bored in Bogota.LOL
R
Old December 29th 17, 01:40 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
I have one of these stainless steel versions.
https://www.amazon.com/dp/B00I1D4S9C...114212990_n_id
Old December 29th 17, 02:44 PM posted to rec.aviation.soaring
Daniel- Sorry. The link I posted was for a passive, wind powered vent. I put a Nicro Solar Vent on my trailer about eight years ago and it is still merrily spinning away in the 300+ days per year of New Mexico sun.
https://www.amazon.com/s/?ie=UTF8&ke...l_5a1el56vm1_e
Old December 29th 17, 07:14 PM posted to rec.aviation.soaring
AS
I went through a few of these types of solar powered vents on my old trailer. The one common mode of failure for all of them was that the clear resin covering the solar panels turned hazy-yellow, similarly to what the head-light covers of later model cars look like after a few years in the south. Apparently, that resin was not the most UV-resistant. One of these vents came with a clear plastic cover which protected the panel from rain. That worked well until it too turned yellow. However, cleaning it with some soft-scrub compound cleared it up again. Finally, that clear cover showed crazing and stress cracks. UV and plastics just aren't friends, I guess.
A SS-version with a glass cover would be nice.
Uli
Old December 29th 17, 08:39 PM posted to rec.aviation.soaring
JS[_5_]
Uli
From experience, the optional solar vent from Cobra does not last long in the desert Southwest. The older Nicro 'Day and Night' vents were great, but the motor in the newer ones doesn't last long and isn't any sort of standard part.
I'm considering the Flettner TCX2. Industrial grade passive vent, with a lifetime warranty.
https://www.inlad.com/flettner-rotar...2?page_id=1157
Wonder if the black vent is more UV resistant than the white one, like the wheel chocks from Cobra?
Old December 29th 17, 09:37 PM posted to rec.aviation.soaring
If it's a good clear cover, it has a UV spray on it.
If not, sand it to clear (as low as 140 wet up to 1500 wet) then use a UV cureable to last 5+ years. I do plastic headlight refinishes, so I have a background.
Toothpaste, and others, last a few months......so it goes.......
Trailer Vent Fan JJ Sinclair[_2_] Soaring 8 September 20th 15 02:07 PM
Solar Vent solution? Bastoune Soaring 6 December 3rd 13 04:23 AM
New Vent! sisu1a Soaring 34 December 10th 10 12:59 AM
How to check functionality of solar vent on Cobra trailer? Matt Herron Jr. Soaring 10 September 27th 10 03:57 AM
Tail Vent? jjcact Soaring 1 June 10th 05 03:10 PM
