Fuselage cradle - New carpet
Old January 4th 18, 10:27 AM posted to rec.aviation.soaring
Colin Roney
Default Fuselage cradle - New carpet
Any ideas on how to keep the new carpet layer attached to
the complete steel curved surface until the glue goes off
apart from using the fuselage itself?
Old January 4th 18, 12:03 PM posted to rec.aviation.soaring
AS
Sand bags or a contractor-grade trash bag filled with water to create an even pressure around the contoured surface.
Uli
'AS'
Old January 4th 18, 12:24 PM posted to rec.aviation.soaring
Roy B.
I use 3M brand spray adhesive. It's very tacky right away and the carpet sticks as soon as it is laid on. The more you spray - the stronger the bond. Good for fuselage dolly, tail dolly, etc.
Roy
Old January 5th 18, 04:05 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
Roy
Definitely 3M spray adhesives are the way to go. There are two general types.
1) 3M Super 77 which is for thinner non-porous materials - spray on and boom things are together forever. You won't get a second chance to adjust things.
2) Foam Fast 74 which I would recommend for porous materials like carpeting - spray on and wait for it to get tacky before placing the material, you will still have some ability to move things around for a bit of time.
Watch out for over spray. I'd practice on some scrap material.
Best of luck.
lining for fuselage cradle? Colin Roney Soaring 5 December 3rd 17 11:01 PM
Keeping Carpet from Sliding? JB Owning 6 March 30th 06 04:04 AM
F-18 Magic Carpet Ride Larry Dighera Piloting 11 March 13th 05 07:13 PM
Cobra Carpet Janus2k Soaring 4 August 28th 04 04:22 AM
Cobra Interior Carpet Glue Brian Iten Soaring 7 August 24th 04 05:35 AM
