Good lubricant for assembly
Old May 26th 18, 02:34 PM posted to rec.aviation.soaring
Senna Van den Bosch
Default Good lubricant for assembly
I'm trying to find a good lubricant for assembly, available in Europe. Any ideas? Currently using regular vaseline.
Old May 26th 18, 03:41 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I understand vaseline is not good for composite structures .
Old May 26th 18, 04:16 PM posted to rec.aviation.soaring
Dan Daly[_2_]
http://www.millenair.nl/shop/pilot-s...bearing-grease
Old May 28th 18, 07:09 AM posted to rec.aviation.soaring
2G
I use a silicon lubricant spray, but any light oil will do.
Tom
Old May 28th 18, 08:01 AM posted to rec.aviation.soaring
If the manufacturer specifies a lubricant, use it. If the manual just says something like "Use a non-cold coagulating grease" Aeroshell 33 is good stuff. Hell to get off of your clothes though.
Old May 28th 18, 04:41 PM posted to rec.aviation.soaring
Papa3[_2_]
This request comes up periodically; you could search old threads for the long and very passionate responses :-)
I like Superlube, which is a synthetic grease that is very temperature stable over the range that we tend to fly sailplanes. Great for main pins and other fittings. There's also a spray lube from the same manufacturer for those drives and other fittings that call for it.
Quick check on Amazon DE shows it's available there.
P3
Old May 28th 18, 08:03 PM posted to rec.aviation.soaring
MNLou
P3
What Papa3 said.
Lou
Old May 28th 18, 10:12 PM posted to rec.aviation.soaring
bumper[_4_]
What Lou said. :c)
Old May 28th 18, 10:18 PM posted to rec.aviation.soaring
What Bumper said.
Great stuff
Old May 29th 18, 02:28 AM posted to rec.aviation.soaring
Use Vaseline on your girlfriend if you can't find better stuff in an emergency situation.
For important things like your glider, Super Lube is better, although I also like Exxon/Mobil synthetic grease.
https://www.amazon.com/Super-Lube-21...ase+super+lube
https://www.amazon.com/Mobil-105527-.../dp/B000LDJ3XQ
Lubricant for spar pins Jonathan St. Cloud Soaring 38 January 10th 18 04:29 PM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6973027.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility 6973447.jpg [email protected] Aviation Photos 0 April 11th 07 02:43 AM
Best lubricant for Mechanical Tachometer Cable??? RonLee Home Built 3 January 4th 05 12:04 AM
