Trailer shade
Old July 8th 18, 09:47 PM posted to rec.aviation.soaring
Default Trailer shade
My Trailer is kept outdoors during the summer.
Thinking about a shade to protect it from the sun.
Anyone has any ideas/experience ?
Dan
Old July 8th 18, 10:32 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
On Sun, 08 Jul 2018 13:47:45 -0700, crosscountryboxco wrote:
My Trailer is kept outdoors during the summer. Thinking about a shade to
Dan
I have an alloy skin box trailer. In 2014 it was starting to look
somewhat tatty, so in September we took it back to primer by using a
rotary steel brush on the seams and an orbital sander on the rest of its
surface. Then we painted it arctic white using an acryllic automotive
trailer paint from a local dealer who supplies the car refinishing and
customizing crowd. We put a coat of primer and two coats of paint on
using rollers. The result was a huge improvement in appearance.
My trailer is parked on the club airfield from mid-March until some time
in November[1]. Its still looking very good with no sign of the paint
weathering or undue leaks.
[1] It over-winters in a local farmer's grain barn, which is dry if not
exactly warm. We put our trailers in this winter storage one the farmer
has sold the grain and emptied the barn.
Martin | martin at
Gregorie | gregorie dot org
Old July 9th 18, 12:35 AM posted to rec.aviation.soaring
Nick Kennedy
Maybe find the side of a hanger?
That's what I do FWIW
Old July 9th 18, 01:26 AM posted to rec.aviation.soaring
A small pole barn should do the trick.
Old July 9th 18, 02:50 AM posted to rec.aviation.soaring
Craig Reinholt
Dan
https://www.capa-shop.de/schutzhaube...anhaenger.html
Should do the trick.
Old July 9th 18, 09:57 AM posted to rec.aviation.soaring
Dan
About 12-13 years ago I bought a RV/trailer/boat shelter kit that was plenty big for a Cobra 15 Meter Trailer. The kit uses prefabricated welded tubular fittings and locally purchased chain link fence tubes and a 20-foot by 30-foot tarp. The local fence tubes can be easily cut with a tubing cutter and the tarp is attached with bungees and can easily be removed in case of an approaching hurricane. I have relocated the whole thing a couple of times.. The one I have is kind of a "gambrel" roof where the sides of the tarp come down to just a couple of feet above the ground. When the tarp started to weather I painted it with white acrylic paint. Sorry that I cannot remember where I got it but a web search might find it.
Old July 9th 18, 01:25 PM posted to rec.aviation.soaring
Plenty of temporary shelters on the web. Found this one in ten seconds by searching for temporary tents. This one is a bit short at 26 ft. but you get the idea.
https://www.hayneedle.com/product/en...02&tid=NA052-1
Old July 9th 18, 02:00 PM posted to rec.aviation.soaring
Dan
We have been using "portable garages" which are basically opaque green house structures for about 15 years with good results.
Shelterlogic has been our source. We buy a 14 by 32 shelter that will hold 2 trailers. Cost is on the order of about $2400. They do need to be well secured to the ground. Also make sure ventilation is good.
There are many sources for these products.
Good luck
UH
Old July 9th 18, 03:48 PM posted to rec.aviation.soaring
Dan
Rex Mayes has trailer covers..."Williams Soaring"
Old July 9th 18, 04:32 PM posted to rec.aviation.soaring
Thank you all !
Great advice.
Dan
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
TV-1 trailer for Let 33 BobWa43 Soaring 4 April 22nd 10 12:19 AM
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 10:24 PM
Emergency Sun-Shade for Skylab Orbital Workshop 7040525.jpg [email protected] Aviation Photos 0 April 9th 07 01:36 PM
