Need tail wheel assembly
Old July 25th 18, 01:49 AM posted to rec.aviation.soaring
MNLou
Default Need tail wheel assembly
I need to replace the entire pneumatic tail wheel unit on my 2006 LAK17AT - bearings, rim, tube, and tire.
Does anyone have a source they could recommend?
Thanks in advance!
Lou - cross posted from the LAK17 Yahoo Group
Old July 25th 18, 04:27 PM posted to rec.aviation.soaring
JS[_5_]
Thanks in advance!
If it's a common size, call Wings And Wheels.
Also consider your W+B while doing this, now might be the time to use the brass tailwheel option should you wish to move C/G aft.
Old July 25th 18, 08:42 PM posted to rec.aviation.soaring
Thanks in advance!
Now, how did you destroy the entire wheel, Lou? There got to be story behind your question. Come on, entertain us, please.
Old July 25th 18, 09:15 PM posted to rec.aviation.soaring
Thanks in advance!
Some LAK's use a tail wheel that is like a small wheel chair wheel. One I had to replace was plastic and not at all durable.
FWIW
UH
Old July 25th 18, 10:47 PM posted to rec.aviation.soaring
Bob Kuykendall
The ones in the HP-24 kits come from Monster Scooter Supply; they're the standard 200x50 Razor scooter front wheel. We haven't had any trouble with them.
--Bob K.
Old July 26th 18, 03:15 AM posted to rec.aviation.soaring
WB
Thanks in advance!
I have had good results searching for tailwheels for gliders at wheel chair parts sites. Google "wheelchair front caster". My favorite supplier "MobilityDirect" appears to have gone away, unfortunately. http://www.wheelchairparts.net may be a good place to start.
Old July 26th 18, 04:19 AM posted to rec.aviation.soaring
AS
That's the place I got a new tail-wheel tire for my Libelle, which was white and an odd size. They seemed to have a good selection.
Uli
'AS'
Old July 26th 18, 06:36 AM posted to rec.aviation.soaring
Paul Agnew
https://fbw-flugzeugbau.de/parts-for...c8q c6ejlkk57
Lak not listed specifically, but does it look like one of these?
Paul A.
ASW19
Correct adhesive to use to attach tail wheel assembly. Tony[_5_] Soaring 7 April 3rd 18 03:05 AM
Correct adhesive to use to attach tail wheel assembly. Cookie Soaring 0 April 1st 18 05:49 AM
Correct adhesive to use to attach tail wheel assembly. NG[_2_] Soaring 0 April 1st 18 03:36 AM
spare tail dolly wheel assembly [email protected] Soaring 3 February 19th 15 02:29 PM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 01:34 PM
