Interesting new solar glider
Old August 23rd 18, 01:49 AM posted to rec.aviation.soaring
AS
Default Interesting new solar glider
Just reposting here what is being discussed on the German forum. Looks like an electrified Sparrow-Hawk.
https://www.byeaerospace.com/bye-aer...es-1st-flight/
Here are some pictures of the maiden flight:
https://newatlas.com/bye-aerospace-s...55969/#gallery
Interesting development ...
Uli
'AS'
Old August 23rd 18, 02:20 AM posted to rec.aviation.soaring
Matt Herron Jr.
Uli
'AS'
Both links appear to be broken...
Old August 23rd 18, 03:36 AM posted to rec.aviation.soaring
kinsell
Uli
'AS'
First link has some content, if you scroll down. At least for me. Top
level of website is https://www.byeaerospace.com/
I think they're promoting this more as an electric airplane, rather than
a motorized glider. 2000 watts isn't much to keep a two-place airplane
in the air.
Old August 23rd 18, 12:52 PM posted to rec.aviation.soaring
Emir Sherbi
Uli
'AS'
in the air.
Yes, 2kW is not much energy.
But consider that in high altitude that ship could need only 4-5kW to maintain a sustained flight. With clear sky and in noon you can save as much as the half of the battery's energy.
Old August 23rd 18, 03:17 PM posted to rec.aviation.soaring
kinsell
Uli
'AS'
in the air.
4-5KW is about 6 HP. I think 20 is a better number than 6 for sustaining.
Clear sky at noon, middle of the summer, with none of that California
smoke drifting into Colorado, and you still won't see much benefit from
that 2KW in the air (assuming they really get 2 KW). Maybe recharging
on the ground is what they're going after.
Old August 23rd 18, 04:21 PM posted to rec.aviation.soaring
Emir Sherbi
Uli
'AS'
in the air.
4-5KW is about 6 HP. I think 20 is a better number than 6 for sustaining..
Its almost a glider... 5kW is a good number for sustained flight.
Luka´s FES system uses 4kW, you can check it out in videos and brochures.
Old August 23rd 18, 04:29 PM posted to rec.aviation.soaring
Kevin Neave[_2_]
Unless the sky is completely dead D2C-FES uses about about 2-4kW to get
maximum endurance. Doesn't climb at that but has *really* long legs to make
the most of any energy left in the sky.
KN
Looks
Uli
'AS'
Top
than
airplane
in the air.
sustaining.
Old August 23rd 18, 07:00 PM posted to rec.aviation.soaring
Ben Hirashima
According to the New Atlas article, the aircraft is intended to be a drone. If the payload weighs less than a human pilot, maybe 2000 watts would be enough to sustain flight.
Old August 24th 18, 01:50 AM posted to rec.aviation.soaring
Nothing new. A standard 1-26 is solar powered😁
Old August 24th 18, 03:13 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
And has a TON more wing area for those solar cells to power the motor.
RTW Solar Impulse 2 Kilo-Bravo Soaring 5 March 17th 15 07:17 AM
solar glider video Peter Scholz[_2_] Soaring 8 September 21st 10 02:40 PM
Solar Flight Much more interesting than Hilarious Video Richard[_1_] Soaring 0 December 5th 08 04:07 PM
Interesting thread in Rec.av.homebuilt about using plywood toform glider Shawn Home Built 2 April 11th 05 08:28 PM
Solar Turbines [email protected] Rotorcraft 2 January 16th 05 01:30 PM
