ADS-B equiped glider in USA Contests.
Old January 30th 19, 12:43 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Default ADS-B equiped glider in USA Contests.
What will the rules committee will have to say now that we can see ADS-B equiped gliders and their data on PowerFlarm at 20 to 30 NM.
Richard
Old January 30th 19, 12:50 AM posted to rec.aviation.soaring
Darryl Ramm
Richard
Or at 50 or more miles...
14 CFR 91.225 requires an aircraft with ADS-B Out installed to operate it at all times. So...
Old January 30th 19, 10:35 AM posted to rec.aviation.soaring
Richard
And does that only apply to certified gliders...
The requirements of paragraph (b) of this section do not apply to any aircraft that was not originally certificated with an electrical system, or that has not subsequently been certified with such a system installed, including balloons and gliders.
Old January 30th 19, 09:05 PM posted to rec.aviation.soaring
Richard
The RC has been aware of the capabilities of ADS-B for as long as I can recall. If you go back and read some of the RC Meeting minutes over the past 5-6 years you will find regular discussion of ADS-B capabilities along with topics like Flarm and Flarm Stealth or Competition modes. The current posture of the RC is to be very cautious about restrictions on technology - this is particularly true about FAA mandated or regulated safety equipment.
Certainly there is lots of discussion across the global soaring community about how technology may be used tactically in competition at what that might mean for the fairness and enjoyment of glider racing. Speaking personally, I'd be very wary about attempting to restrict information available to pilots - particularly when that information overlaps with what might be relevant to safety of flight.
Lastly, I'd argue (my personal view, not a formal position of the RC), that the primary tactical usefulness of position, altitude or rate of climb information is over distance and time horizons that could be taken advantage of by a competitor. For the most part that is at distances of less than 10 miles, or around the limit of Flarm today. The existence of ADS-B, therefore, makes the idea of banning Flarm or mandating Stealth mode less likely, but in and of itself doesn't confer much in the way of new useful information.. Put another way, I probably don't care that much to know that you found a great thermal 30-50 miles from my position. It might make some marginal difference in knowing where the pack is going on a sketchy day, but I'm not sure I see that as a big deal or necessarily a bad thing if it reduces handouts. The bigger competitive issue globally is about mass gaggles and close-in leeching. That's only partially a technology problem. Start procedures and scoring formulae also figure prominently,
King Canute tried to order the tide not to rise. It didn't work out.
Andy Blackburn
9B
Chair, SSA Competition Rules Committee
(Opinions expressed here are my own)
Old February 2nd 19, 10:52 PM posted to rec.aviation.soaring
Darryl Ramm
Richard
Lastly, I'd argue (my personal view, not a formal position of the RC), that the primary tactical usefulness of position, altitude or rate of climb information is over distance and time horizons that could be taken advantage of by a competitor. For the most part that is at distances of less than 10 miles, or around the limit of Flarm today. The existence of ADS-B, therefore, makes the idea of banning Flarm or mandating Stealth mode less likely, but in and of itself doesn't confer much in the way of new useful information. Put another way, I probably don't care that much to know that you found a great thermal 30-50 miles from my position. It might make some marginal difference in knowing where the pack is going on a sketchy day, but I'm not sure I see that as a big deal or necessarily a bad thing if it reduces handouts. The bigger competitive issue globally is about mass gaggles and close-in leeching. That's only partially a technology problem. Start procedures and scoring formulae also figure prominently,
Andy Blackburn
9B
Nice answer Andy.
Amusingly I did hear second-hand reports that seeing an ADS-B Out equipped glider at great distance via PowerFLARM 1090ES-in was annoying some pilots in contest situations. I have no clue why, maybe it was their display showing targets at the edge of the display and the range was unclear or was it frustration that the other aircraft was so far ahead, or just climbing better?
But hey if having ADS-B Out annoys other contest pilots it may be a great competition ploy :-) Folks with Trig transponder today that "annoying gizmo" only costs you a few hundred dollars (but please, if you do this, for overall safety do a TABS or 2020 Compliant install, not any old NMEA GPS driving the Trig transponder).
Old February 3rd 19, 01:46 AM posted to rec.aviation.soaring
Ramy[_2_]
The reality is that the increasing number of ADSB aircrafts nowadays will literally clutter your screen and audio alerts if you don’t reduce the range to something like 5 miles and 1000 feet altitude range so you only get alerts from aircrafts in the vicinity. At least when flying near the Bay Area I found I have to limit the ADSB range, so no much of improved range over flarm.
Ramy
Old February 3rd 19, 03:48 PM posted to rec.aviation.soaring
Dan Marotta
What Ramy says.Â* I've got the alert ranges turned down on my Flarm. Why
bother with distant traffic?Â* I haven't done that on my iPad yet in the
C-180 and the screen gets really cluttered around airports.
I have to take care of that...
Ramy
Dan, 5J
Old February 3rd 19, 04:06 PM posted to rec.aviation.soaring
Ramy
A related question: When towing behind Keith E.'s 182 at Parowan my PFLarm sounded a new and totally annoying alarm. It turned out to be the ADS-B out signal from that towplane. While I could silence the alarm by pushing the appropriate button, it came back after a minute or so. How are we going to deal with that when in a busy thermal with 10 other ADS-B out transmitting gliders?
Herb
Old February 3rd 19, 04:41 PM posted to rec.aviation.soaring
son_of_flubber
On Sunday, February 3, 2019 at 11:06:22 AM UTC-5, wrote:
...When towing behind Keith E.'s 182 at Parowan my PFLarm sounded a new and totally annoying alarm. It turned out to be the ADS-B out signal from that towplane. While I could silence the alarm by pushing the appropriate button, it came back after a minute or so. How are we going to deal with that when in a busy thermal with 10 other ADS-B out transmitting gliders?
Doesn't Powerflarm filter out the spurious ADS-B proximity warnings when BOTH aircraft have Powerflarm (and 1+ aircraft have ADS-B-out)?
Old February 10th 19, 12:42 AM posted to rec.aviation.soaring
Richard
The LX90xx manual describes the FLARM 'Dismiss Time' software button as programmable from 0 to 120 seconds. I'm not sure where this is programmed, but the default appears to be 1 minute. It would be nice if LX could add a 10 min Dismiss Time button; one that you could deselect would be a bonus.
Charlie
FES in Contests MNLou Soaring 43 November 3rd 14 03:18 PM
currency for contests Brad[_2_] Soaring 10 June 1st 11 06:49 AM
Contests the end-all? Morgans[_2_] Soaring 29 May 21st 10 11:10 PM
GPS interference and contests Bill Daniels Soaring 25 January 25th 08 05:57 AM
ideas for fun contests at fly-ins Hoot Piloting 9 April 30th 04 10:58 AM
