3M Perfect it and WX Block&Seal
Old May 3rd 19, 09:21 PM posted to rec.aviation.soaring
soaringjac
Default 3M Perfect it and WX Block&Seal
I bought both from WW and i am wondering if i should apply both? or is that just overkill? I the description of the 3M stuff it says you can follow up with WX block/seal. Just not sure if i should apply the 3M stuff and then apply thw WX. Now that i really think about it it kind of seems like i should just do one or the other. Thoughts?
Old May 4th 19, 02:40 AM posted to rec.aviation.soaring
Mike C
If your glider needs buffing, first use the Perfect-It. WX products are nice for protecting the surface after buffing.
Old May 4th 19, 03:40 AM posted to rec.aviation.soaring
soaringjac
Thanks Mike!
Old May 4th 19, 04:55 PM posted to rec.aviation.soaring
Matt Herron Jr.
First:
3M Perfect-It Rubbing Compound (06085)
Then
3M Perfect-It Machine Polish (06064)
Finally
wax of your choice
Don't forget to mask your seals and turbulators with masking tape to protect them from the buffer
I just did my wings last weekend and they turned out great
Old May 4th 19, 05:09 PM posted to rec.aviation.soaring
soaringjac
First:
Then
Finally
wax of your choice
Thanks Matt
WX Block life? [email protected] Soaring 1 April 8th 19 01:44 PM
WX block and seal question Brad[_2_] Soaring 15 July 7th 17 03:35 PM
Need WX BLOCK & WX SEAL Bill G Soaring 0 July 6th 17 01:06 AM
LS4 aileron gap seal and mylar seal width Eric Foertsch Soaring 8 May 18th 17 08:50 PM
WX Block/WX Seal Question vontresc Soaring 1 March 10th 15 08:43 PM
