Discus B canopy hinge repair
Old June 6th 19, 03:42 PM posted to rec.aviation.soaring
Default Discus B canopy hinge repair
Has anyone out there had any experience with a loose aft canopy hinge on a Discus B? I am working with the owner of his Discus and the aft hinge is noticeably loose as it sits in the frame.
Details from Schempp Hirth are a bit vague with respect to the replacement hinge which the owner has purchased.
Specifically, I require details on how to excavate the cavity around the hinge and then what weight of carbon fibre cloth is used to overlay the hinge on the outside of the frame.
cheers
mike
Old June 8th 19, 12:28 AM posted to rec.aviation.soaring
cheers
mike
If the looseness is due to a broken hinge, then you are replacing the hinge..
If it is broken loose from the frame, it may well be a matter of working resin into the joint, with the last mixed with thickener, and then placing back on the fuselage to hold the correct position until it is cured. Make sure the fuselage is well waxed and masked outside the work area.
UH
Grob twin II rear canopy hinge release mechanism mas Soaring 2 July 5th 17 06:06 PM
DG-505 cracked canopy repair haven Soaring 3 June 12th 08 03:24 PM
Canopy repair products [email protected] Soaring 3 December 30th 06 02:46 PM
Duo Discus canopy problems David Starer Soaring 4 June 20th 04 11:09 PM
Canopy crack repair Pete Brown Soaring 0 May 18th 04 03:09 AM
