Dittel FSG 2T question
Old June 12th 19, 05:03 PM posted to rec.aviation.soaring
SC
Default Dittel FSG 2T question
Has anyone successfully used pin 4 to connect a vario audio to the speaker for a Dittel FSG 2T radio? I tried this with a ClearNav Vario and was not successful. The manual indicates that this should work, but states that this feature is optional. I don't know if this means that it is an optional connection or if it is an optional feature for the radio. I am trying to eliminate a speaker in the cockpit.
Thanks, Sandy
Old June 12th 19, 05:29 PM posted to rec.aviation.soaring
JS[_5_]
Thanks, Sandy
Available on a lot of radios. I haven't tried it, primarily since every radio will mute or at least duck the auxiliary audio with radio reception and the audio vario will be lost.
Old June 12th 19, 05:49 PM posted to rec.aviation.soaring
MN50
Thanks, Sandy
Did you alter Jumper J303? See paragraph 3.4.5 in the manual.
Dittel FSG 71 M Help Nick Kennedy Soaring 7 November 8th 13 07:22 PM
Dittel FSG 50 in Dittel base station [email protected] Soaring 2 February 18th 09 09:15 AM
Dittel FSG 50 in Dittel base station, Perfect for crews and FBO [email protected] Soaring 1 February 18th 09 09:15 AM
Dittel Joseph L. Hyde Soaring 2 July 12th 05 03:25 PM
Dittel FSG 15 A. Wolfert Soaring 0 December 18th 04 01:14 PM
