Supplemental oxygen
Old July 22nd 19, 04:50 PM posted to rec.aviation.soaring
2G
Default Supplemental oxygen
The other day a couple of pilots were treating 123.3 as their private chat line which I was forced to listen to so I could hear my friend's hourly position reports. One of the things one kept (repeatedly) talking about was having to descend to 12,500 to "reset" the 30 minute clock. This is entirely wrong: there is no "resetting" of the clock; it is a ONCE A FLIGHT exception, no doubt intended to give pilots w/o supplemental oxygen leeway in crossing high-altitude mountain passes. The governing FAR is 91.211:
§ 91.211 Supplemental oxygen.
(a)General. No person may operate a civil aircraft of U.S. registry -
(1) At cabin pressure altitudes above 12,500 feet (MSL) up to and including 14,000 feet (MSL) unless the required minimum flight crew is provided with and uses supplemental oxygen for that part of the flight at those altitudes that is of more than 30 minutes duration;
(2) At cabin pressure altitudes above 14,000 feet (MSL) unless the required minimum flight crew is provided with and uses supplemental oxygen during the entire flight time at those altitudes; and
(3) At cabin pressure altitudes above 15,000 feet (MSL) unless each occupant of the aircraft is provided with supplemental oxygen.
Old July 22nd 19, 05:42 PM posted to rec.aviation.soaring
Great point.....
While never having to deal with this issue....my feeling (and FAA/NTSB if an incident or accident....), bouncing low for a short bit does NOT agree with Mother Nature.
While "maybe legal" (emphasis on MAYBE), Mother Nature is almost as a hard a judge as gravity (yeah....I know....no such thing as gravity.....the earth sucks.....you get the point....).
Sounds like this pilot may become a statistic....sucks for everyone else as well as family and friends.....:-(
Old July 23rd 19, 01:57 PM posted to rec.aviation.soaring
I would have jumped on the party line and told them anonymously 1) please go to 123.5 and 2) BTW your thoughts on resetting the oxygen clock defies all medical knowledge and you are seriously risking hypoxia.
Old July 23rd 19, 04:21 PM posted to rec.aviation.soaring
This was very helpful! I have had oxygen system crap out twice while flying over the Great Basin and bounced between 12,499 and 13,999 for the rest of the flight to get home. Good to know going below 12.5k doesn’t “reset” the 30 min timer.
Cheers!
Bruno - B4
Old July 23rd 19, 04:57 PM posted to rec.aviation.soaring
Tango Eight
The smart guys are on O2 at 10,000 during the day and 5,000 at night. Most humans are measurably impaired at 12,500.
T8
Old July 23rd 19, 05:10 PM posted to rec.aviation.soaring
gkemp
T8
The Air Force have done tests that show flight decision making can be negatively affected without supplemental Oxygen above 6000 feet. I always put mine on when I got into the cockpit when releasing above 6000 feet.
gkemp
Old July 23rd 19, 05:26 PM posted to rec.aviation.soaring
O2 systems fail. Probably, the best thing you could do, would be go thru a altitude chamber course. Everyones symptoms are different and it is insidious while its happening. knowing your symptoms and when it(hypoxia) is happening to you, can be a life saver! I went threw a course at ASU a few years back. Recently while flying a friends glider in Moriarty, I noticed my symptoms gradually appearing (tingling o, the back of the neck and headache). This lead me to check the EDS system and realize it was not fuctioning properly. I was able to reset it and get it working so didnt abort but had I not recognized the problem------
CH
Old July 23rd 19, 06:08 PM posted to rec.aviation.soaring
John McCullagh[_2_]
T8
Much depends on your age, fitness, smoking habits, medication such as
beta-blockers, length of flight and the altitude at which you normally
live. At 10,000ft, you need 30% oxygen to function as well as normal if you
live at sea-level. Since air is 21% oxygen: that is a 50% increase. Even
10,000 ft is too high without supplemental oxygen for many middle-aged
pilots who should be using a pulsed-demand supply soon after take-off for
high flights. The law is set in much the same way as blood/alcohol levels.
If you stay within legal limits, it does not mean that you are flying as
safely as you could. For example: visual sensitivity at night is decreased
by 10 percent at 5,000 ft and by 30 percent at 10,000 ft. Even in the day
at 10,000 ft there are reductions in memory capacity, patience, focus,
endurance etc. Jean-Marie Clement's book has 39 pages on the subject!
Old July 23rd 19, 06:21 PM posted to rec.aviation.soaring
Steve Koerner
On a related note, if you run out of oxygen, you can get yourself some extra altitude margin in a pinch by pressure breathing. I rather discovered this while swimming laps. I could do better with a controlled pressurized exhale. I figured the same idea might transfer to soaring. I did some reading that supported the premise and then did some experimenting at altitude. It definitely works (legalities aside). Having 45 years of western soaring under my belt, I have a better than average sense for my own personal oxygen requirements. My tentative conclusion is that, for me, pressure breathing is worth around three thousand feet. Certainly I'm not recommending pressure breathing in lieu of supplemental oxygen, but it might be a useful thing to know about just in case.
Old July 23rd 19, 06:23 PM posted to rec.aviation.soaring
Agreed.....what is the cost of an O2 refill vs. a bad outcome?!?!??
Poor physical health, smoking (my bad....don't harp....I get enough already....), lack of sleep, different start point (coastal pilot suddenly flying at Denver or similar....) etc.
In general, I see no real downside to excess O2 other than sorta hyperventilating.....not great, but the opposite is way worse.
When you go O2 low, first thing to go is higher thinking.....exactly what you need then.....
No....have not done an altitude chamber....
No....have not done much flying above 10K'ASL.....
Yes, did a gold climb with no external O2 to about 13.5K' on the eastern seaboard.
Oudie Supplemental Power Pack Roy B. Soaring 24 September 30th 17 06:46 PM
Oxygen Jim[_18_] Soaring 5 September 28th 11 11:59 PM
News flash: pilots are "allowed" to use supplemental oxygen VARR Soaring 8 August 17th 08 04:54 PM
SZD-55 and oxygen David Pye[_2_] Soaring 0 February 27th 07 08:04 AM
Supplemental O2 and children Peter R. Piloting 23 April 18th 06 01:47 PM
