Howdy,
Does anyone have experience with GS-AIR combination LED position lights / strobe unit, and the double flash stobe driver? Are the airworthy inspections passing with these units? This URL will get you to their site: https://ssl.perfora.net/gs-air. com/sess/utn;jsessionid=1541242ca9a52cb/shopdata/index.shopscript thanks, tom pettit |
I have no experience with these, but the LED model looks awesome! Very
light-weight and low-drag design could be real nice. I had trouble with the link you gave, but found them at www.gs-air.com It seems they were designed to run with the triple flash strobe system which weighs only 15 oz, compared to the double flash which is 2.5 lbs! I am sure that either would drive them though. Thanks for the lead on this!! wrote in message news ![]() Howdy, Does anyone have experience with GS-AIR combination LED position lights / strobe unit, and the double flash stobe driver? Are the airworthy inspections passing with these units? This URL will get you to their site: https://ssl.perfora.net/gs-air. com/sess/utn;jsessionid=1541242ca9a52cb/shopdata/index.shopscript thanks, tom pettit |
A strobe bulb doesnt know, or care, how many flashes its being given.
You could hook it up to a quad flash just as easily. All flashes are the same intensity and duration. By sequencing them in rapid, close succession, the strobe is perceived to "dwell" for the duration of the series. Dave firstflight wrote: I have no experience with these, but the LED model looks awesome! Very light-weight and low-drag design could be real nice. I had trouble with the link you gave, but found them at www.gs-air.com It seems they were designed to run with the triple flash strobe system which weighs only 15 oz, compared to the double flash which is 2.5 lbs! I am sure that either would drive them though. Thanks for the lead on this!! wrote in message news
| Thread Tools | |
| Display Modes | |
| Panel Lights - Need Help | Barnyard BOb - | Home Built | 2 | May 29th 04 08:51 PM |
| Panel Lights Dimmer | MII Driver | Home Built | 3 | April 3rd 04 02:56 AM |
| LEDs for Nav Lights - Jim Weir | Scott Gettings | Home Built | 3 | February 17th 04 02:53 AM |
| What are you guys using for cockpit lights these days? | Stealth Pilot | Home Built | 6 | December 9th 03 10:14 AM |
| LED for position lights | Jerry Springer | Home Built | 2 | August 19th 03 02:43 AM |
