Kobo vs Nook
Old September 24th 19, 06:06 PM posted to rec.aviation.soaring
6PK
Default Kobo vs Nook
I have been running a Kobo Glo for three seasons now and for the most part I'm happy with it. The one problem I had encountered a few times when down low in the heat, the screen tends to fade out but so far every time it recovered-no problem it had never crashed.
I just wondered if anyone experienced the same and if there is a cure.
Also how does the Nook compare to the Kobo, would be interesting to know.
Old September 24th 19, 08:16 PM posted to rec.aviation.soaring
David Hirst
I used Kobo Minis for a while and had several with 'screen fade' issues. It seems to be a manufacturing batch issue; some I had were just fine and others were hopeless from day 1. Others I've spoken to had no problems ever, but I note that none of them were here in NZ (we often seem to get sent the tail end of the quality bell-curve). If you've got one that works, even if it fades intermittently, then stick with it. I have no experience with the Nook.
I ultimately got fed up with replacing Kobos and went for an Onyx Boox - Android e-ink with WiFi and a proper touch screen (so it still keeps working in strong sunlight). They've put some effort into improving image quality and reducing ghosting, and I've never had a problem with it after three seasons.
DH
TX
Old September 25th 19, 12:25 AM posted to rec.aviation.soaring
6PK
DH
TX
snip;
"I ultimately got fed up with replacing Kobos and went for an Onyx Boox - Android e-ink with WiFi and a proper touch screen "
Excuse my ignorance but I have never heard of this device. If you could elaborate on it a little it would be helpful. Works as any Android device with WiFi only connection (gps or flight computer) or could it be Bluetooth, "proper touch screen" ?
Looked it up on the internet kind of expensive but if it works???
Old September 25th 19, 04:19 PM posted to rec.aviation.soaring
Matt McBee
You can buy an IR-rejection frame for the Kobo Mini here.
https://i.materialise.com/en/shop/it...-for-kobo-mini
(I have no affiliation with this company and do not own this product).
Matt
Old September 25th 19, 04:44 PM posted to rec.aviation.soaring
6PK
I'm aware of this device, unfortunately its available for the Glo
Old September 25th 19, 04:55 PM posted to rec.aviation.soaring
6PK
Sorry,correction I meant not available:-)
Old September 26th 19, 08:50 PM posted to rec.aviation.soaring
David Hirst
snip;
(Copied from other thread) I'm using the C67ML Carta+
Here's one for sale:
https://www.amazon.com/Android-Scree.../dp/B072LW7DM7
Official specs here, although their base model is now the Carta2:
https://www.boox.com/boox-c67/
I only used WiFi to download XCSoar. In flight it's hard-wired through its USB connection to a IOIO box, but you could use WiFi on a local network. As it uses an Android OS, there is no need to re-flash its firmware.
The Kobo uses an infrared "touch"screen, that side-illuminates the surface of the screen and detects any shadows from your finger. It's a nice idea but can freeze temporarily in strong sunlight (that overwhelms the IR detectors. The Boox uses good ol' capacitive touch instead.
DH
Old September 26th 19, 08:55 PM posted to rec.aviation.soaring
6PK
That is great David, thank you.
One more question; do you know if other than IOIO is it bluetooth or WiFi connectable to another device (flight computer, Flarm, etc)?
Old September 27th 19, 08:33 PM posted to rec.aviation.soaring
David Hirst
It has WiFi but no Bluetooth. If another instrument can act as a WiFi router or host, then the Boox should be able to connect to it. I say "should" only because I've never tried.
The IOIO box is really just a multi-port serial-to-USB adapter so, in theory should also let you use any BT dongle with an RJ45 connector, or will let you connect to a K6 BT module.
DH
Old September 24th 19, 10:20 PM posted to rec.aviation.soaring
I've used several Nooks for several years. Never a problem with screen fading, but I had some reliability issued with Nooks' touch sensitivity. Not sure how hot your Kobo got, but we had hot sunny weather at the USA Region 1 contest last year, about 95 degrees F, even hotter in the cockpit waiting on the grid ("griddling"), although I shaded the instrument panel. The GPS I then used (cheap serial module, which I grafted onto the Nook) stopped working until it cooled off at altitude, but the Nook worked fine.
Kobo with Cambridge 302 [email protected] Soaring 6 September 1st 15 01:01 AM
Color Kobo Dan Marotta Soaring 3 October 25th 14 11:10 PM
Using the Nook as a navigation instrument Nyal Williams[_3_] Soaring 1 September 5th 14 09:10 PM
New NOOK Simple Touch for XCSoar! [email protected] Soaring 4 November 26th 12 05:50 PM
Using a nook for xcsoar folken Soaring 38 October 21st 12 05:56 PM
