Does anyone know a US source for the solid-tire tailwheel of a 2003 Ventus 2cxm (steerable)? Its marked Downey California, but the maker's name is worn away.
Measure the inner and outer diameter.Â* You may be able to find one at a
wheel chair supply store.Â* I put one on the tail dolly of my Stemme and it works fine, though it doesn't go as fast as a glider tail wheel.Â* Still, at the price, it may be worth a look. On 1/4/2020 2:32 PM, wrote: Does anyone know a US source for the solid-tire tailwheel of a 2003 Ventus 2cxm (steerable)? Its marked Downey California, but the maker's name is worn away. -- Dan, 5J |
This is serendipitous - I was just about to start a new thread to ask
pretty much the same question: is it reasonable and acceptable to the manufacturer, the regulator and insurers if I replace the pneumatic tailwheel of my Ventus with a solid one? My initial thought is that the loss of protection from impacts would be bad for the structure, but then a solid tire can't be much worse than a solid skid, can it? The only difference I can see is that the skid might spread the load, rather than transferring it through the axle mountings? |
Tailwheel | soartech[_2_] | Soaring | 28 | December 13th 12 11:41 PM |
Tailwheel ID | R. Mueller | Aviation Marketplace | 2 | February 5th 08 10:25 PM |
tailwheel | [email protected] | Soaring | 6 | December 16th 06 12:46 PM |
wanted scott 3200 tailwheel /alaskan bushwheel tailwheel | phillip9 | Aviation Marketplace | 0 | June 6th 06 07:57 PM |
First Tailwheel!! | W P Dixon | Piloting | 9 | May 9th 05 09:07 PM |
