Barometric pressure swing
Old March 21st 05, 02:58 AM
M
Default Barometric pressure swing
Anyone knows why the barometric pressure has a much larger swing in
Pacific Northwest (Seattle) than in New Jersey area? I remember back
in the days when I was flying in NYC area a low pressure day would have
an altermeter setting of something like 2980, and a high pressue day
would be something like 3006. Here in Seattle the altimeter setting
can go from 2940 to 3050 in about two days when a strong system passes.
Is it because of the higher latitude (48 north in Seattle vs. 40 north
in Jersey) or is it because the storms in northeastern Pacific being a
lot more severe? Temperature wise Seattle is very mild compared with
the northeast.
Old March 21st 05, 04:21 AM
Icebound
"M" wrote in message
would be something like 3006. .....
I think there is a little bit of selective memory going on, here.
Without trying too hard, I picked up the weekly data archive from NCDC for
JFK for the first week of January, 2005, and it showed a pressure of 1025mb,
which corresponds to an altimeter setting of about 30.25, a far cry from the
30.06 that you specified as a "high" pressure day.
I am betting that if someone cares to spend the time to analyse the NCDC
files
( ftp://ftp.ncdc.noaa.gov/pub/data/globalsod/2005/ )
....for JFK, for example.... then even higher pressures will be found, and
that the pressure variation is not likely to be all that different from the
SeaTac regime.
On the "low" side, it is possible that Pacific winter storms contribute to a
lower-than-normal pressure regime in the Northwest, but it would take some
analyses of the data to convince me. The Northeast gets some pretty decent
low-pressure-systems, too.
29.40 is approximately 995 mb. That is not a really deep low. I know the
northeast occasionally sees lows below 990, even below 980mb (which would
be 28.90) On the high side, 30.50 is about 1032 millibars, not particularly
excessive.
the northeast.
Latitude does have a part to play in that, if a serious non-tropical low
pressure system is moving in some west-to-east path.... and then starts to
deepen significantly.... its track will almost always curve further to the
north.... Hence the more northern areas, such as the Gulf of Alaska,
Hudson's Bay, and the Labrador Coast, are often the areas of the lowest,
lowest pressures. At the same time, the northern continental interiors...
the Canadian Prairies, US Midwest.... will be the scenes of the highest,
highest pressures when they get outbursts of the really cold air from the
Arctic in winter.
It could well be that Seattle's storm-track climate provides for more rapid
variability of pressure day-to-day...if so it would be because more
low-pressure-systems are passing by... There are climate studies available
for individual states... some of which are available on the web...and it
would take somebody some poring over those studies, or over the raw NCDC
numbers, to convince me one way or the other.
Old March 21st 05, 04:39 AM
BTIZ
I'm sure that a few hurricanes.. and winter storms pressing up the coast can
lower the pressure very often on the east coast..
BT
"Icebound" wrote in message
1025mb, which corresponds to an altimeter setting of about 30.25, a far
cry from the 30.06 that you specified as a "high" pressure day.
files
the SeaTac regime.
a lower-than-normal pressure regime in the Northwest, but it would take
some analyses of the data to convince me. The Northeast gets some pretty
decent low-pressure-systems, too.
particularly excessive.
the northeast.
Arctic in winter.
rapid variability of pressure day-to-day...if so it would be because more
available for individual states... some of which are available on the
web...and it would take somebody some poring over those studies, or over
the raw NCDC numbers, to convince me one way or the other.
Old March 21st 05, 05:26 AM
M
I'm sure it's a bit selective memory on my part, but in NW it's very
common in the winter months to have altimeter setting swing from 2950
to 3050 in a day or two, and when the next storm comes in a week, the
cycle happens all over again. I'm pretty sure that you can find such
highs and lows in Northeast if you really look into the yearly records.
However the "normal" cycle from low to high is less dramatic.
back
have
day
NCDC for
1025mb,
from the
NCDC
files
and
from the
SeaTac regime.
contribute to a
some
decent
passes.
know the
would
particularly
excessive.
north
being a
with
the northeast.
low
starts to
to the
lowest,
interiors...
highest,
Arctic in winter.
rapid
available
it
NCDC
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
Why are TE probes so long? Duane Eisenbeiss Soaring 36 May 9th 04 06:58 AM
Cabin Pressure Altitude Greg Esres Piloting 4 March 24th 04 08:35 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
