Rigger Information
Old May 5th 20, 06:55 PM posted to rec.aviation.soaring
cdeerinck
Default Rigger Information
I am looking at getting an electric rigger for a DG-800S 15/18m.
Currently, I am aware of two on the market IMI (Wings and Wheels) and SoaringXX (Cumulus).
Can anyone advise on the differences between the two?
Are there any others out there that I should be checking out?
Does anyone have a used one for sale?
Trying to get one very soon. Thanks for any feedback.
Old May 5th 20, 07:36 PM posted to rec.aviation.soaring
I think the style with 4 or 5 wheels is more stable than the single-axle type...
Old May 5th 20, 07:59 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
SoaringXX from Craggy Aero
http://www.craggyaero.com/ground_handling.htm
Old May 6th 20, 03:16 AM posted to rec.aviation.soaring
2G
I have the IMI rigger. It is well-constructed using quality materials and disassembles into a relatively small package for storage. The remote controls are GREAT! No more back and forth adjustments as you are trying to get the wings aligned. Just be sure that you start with enough remaining travel to get things aligned (pretty much the same issue with any rigger). The only issue I have had with it was that (somehow) the power switch was either left on, or it got bumped and the battery was drained when I was ready to use it. No battery - no rig. Furthermore, the battery was drained so badly that my Hitec X2 would not charge it, so I had to attach my solar panel to get some charge into the battery. Then the clouds blocked the sun! Lesson learned: buy a 2nd battery. But the connections are soldered to the battery terminal, so I had to unsolder them and attach slip-on terminals. Other than that I have no complaints.
The SoaringXX rigger looks very similar and is a little cheaper, but haven't seen it in person to assess its construction quality.
Tom
Old May 6th 20, 08:36 AM posted to rec.aviation.soaring
Colin Roney
Soa=
ringXX (Cumulus).
=20
d=
control=
th=
t=
only=
le=
use=
tha=
get=
lear=
ter=
t=
haven'=
Tom
You need to make sure it is up to the job regarding electric power. I
bought one for a Lak 12 and it simply wasn`t man enough to lift the wing.
They all seem to be underpowered.
Old May 6th 20, 09:53 AM posted to rec.aviation.soaring
Colin Roney
Soa=
ringXX (Cumulus).
=20
and
d=
control=
th=
travel
t=
only=
le=
use=
tha=
get=
lear=
ter=
than
t=
haven'=
Tom
I should have added that a Lak 12 wing weighs in at about 230lbs.
Old May 6th 20, 05:16 PM posted to rec.aviation.soaring
2G
Soa=
ringXX (Cumulus).
=20
d=
control=
th=
t=
only=
le=
use=
tha=
get=
lear=
ter=
t=
haven'=
Tom
I fly an ASH31Mi, not exactly a feather weight. The IMI actuators are rated for 1500 N (337 lb), which should be more than adequate for your LAK 12. One thing that could reduce this is a bad or marginal battery. Try using a larger, temporary battery to see if this is the problem.
https://wingsandwheels.com/power-rigger.html
Tom
Old May 6th 20, 07:39 PM posted to rec.aviation.soaring
As the producer of the WingRigger, I toyed with the idea of remote electric adjustment. I built a few, and made the parts to be retrofittable to existing WingRiggers. I learned that, the more powerful the actuator, the slower it operated due to the gear ratio from the motor to the screw drive. To allow for a faster speed without giving up the lifting capacity, I used an actuator with about 150 lbs. power and also had a 100 lb. gas spring. That seemed to work well. Unfortunately, demand never really developed, so I put the idea aside.
Old May 6th 20, 12:36 PM posted to rec.aviation.soaring
Dave Nadler
On Tuesday, May 5, 2020 at 10:16:12 PM UTC-4, 2G wrote:
No battery - no rig...
Equip your rigger with a long power lead and the same connectors
as your plane battery. Then you can use the plane battery when
you forget something and run down the rigger battery ;-)
PS: Yes, I did need to use that feature once, oops.
Old May 7th 20, 09:06 AM posted to rec.aviation.soaring
David Salmon[_3_]
I decided on an IMI PR due to having had other IMI equipment including a
OMR, and all do the job well.
One point, about 2 years ago at annual inspection, a plastic tube end bung
was found in an inaccessible place in the bottom of my Discus fuselage. It
turned out to be from the OMR (not Power rigger), and must have gone in
through the side where the wing fits. I now glue them in.
Dave do you mean to plug the lead into the Charge XLR on the control
panel?
Also can anyone identify the small green plug and socket used on the
battery?
Dave
Looking to buy a wing rigger. Marcin S Soaring 4 July 19th 17 02:13 PM
Looking for a wing rigger for an asw 20 Marcin S Soaring 1 July 10th 17 02:21 AM
Ka6 wing rigger James Koper Soaring 2 June 22nd 17 03:23 PM
Wing Rigger FS Ron Gleason Soaring 2 December 5th 13 05:36 PM
Looking for a used wing rigger / one man rigger .... [email protected] Soaring 0 November 6th 13 06:02 PM
