Rigger Information
Old May 7th 20, 09:06 AM posted to rec.aviation.soaring
David Salmon[_3_]
Default Rigger Information
At 11:36 06 May 2020, Dave Nadler wrote:
On Tuesday, May 5, 2020 at 10:16:12 PM UTC-4, 2G wrote:
No battery - no rig...
Equip your rigger with a long power lead and the same connectors
as your plane battery. Then you can use the plane battery when
you forget something and run down the rigger battery ;-)
PS: Yes, I did need to use that feature once, oops.
I decided on an IMI PR due to having had other IMI equipment including a
OMR, and all do the job well.
One point, about 2 years ago at annual inspection, a plastic tube end bung
was found in an inaccessible place in the bottom of my Discus fuselage. It
turned out to be from the OMR (not Power rigger), and must have gone in
through the side where the wing fits. I now glue them in.
Dave do you mean to plug the lead into the Charge XLR on the control
panel?
Also can anyone identify the small green plug and socket used on the
battery?
Dave
Old May 7th 20, 10:54 PM posted to rec.aviation.soaring
Dave Nadler
On Thursday, May 7, 2020 at 4:15:04 AM UTC-4, David Salmon wrote:
Dave do you mean to plug the lead into the Charge XLR on the control panel?
No, battery connector so you can unplug the dead inbuilt battery and
connect to a glider battery.
Also can anyone identify the small green plug and socket used on the battery?
I believe that's an MPX power lead as used by SH for battery connections.
While I haven't seen the connector inside the IMI,
MPX is what I used and suggested to IMI as it matched the glider battery.
Example:
https://powerbox-americas.com/produc...90 9604630592
Hope that helps!
Best Regards, Dave
Old May 8th 20, 09:18 AM posted to rec.aviation.soaring
David Salmon[_3_]
panel?
battery?
Example:
Hope that helps!
Best Regards, Dave
Thanks Dave, yes the MPX does look like the connector fitted to the battery
on the IMI PR.
Regards and stay safe
Dave
Looking to buy a wing rigger. Marcin S Soaring 4 July 19th 17 02:13 PM
Looking for a wing rigger for an asw 20 Marcin S Soaring 1 July 10th 17 02:21 AM
Ka6 wing rigger James Koper Soaring 2 June 22nd 17 03:23 PM
Wing Rigger FS Ron Gleason Soaring 2 December 5th 13 05:36 PM
Looking for a used wing rigger / one man rigger .... [email protected] Soaring 0 November 6th 13 06:02 PM
