Break-in Period for 0200A Continental Engine?
Old April 17th 05, 07:42 PM
Larry
Default Break-in Period for 0200A Continental Engine?
I just had my cylinders overhauled and now have 2 hrs on the engine. I
have been getting some mixed information about the proper break-in
procedure. Run "rich" or "lean"?. I am running 40 weight mineral oil.
Some say it is important to run hard and lean to prevent the walls from
glazing others say better to run rich to keep the engine cooler and
protect the valves. My engine oil temp is fine (175-180) and stable. I
don't have a cylinder head temp. I have had a little plug fouling and
one stack is dry black and the other stack is dry gray. I just replaced
a few plugs and hopefully that will fix the fouling problem.
Compression OK and mainly wanted to know about the "lean" or "rich'
issue. Maybe I'll also call Teledyne for the input. I'd appreciate any
thoughts on any of the above. Thanks..
Larry
Old April 18th 05, 05:26 PM
Stealth Pilot
Larry
hunt out the teledyne continental breakin information and use it. gets
rid of all the BS.
Stealth Pilot
Old April 19th 05, 06:07 AM
Paul Folbrecht
Other than RTFM, like the other guy said, you'd probably have better
luck with this question on some of the other r.a. forums (owning,
piloting). Also the Cessna 150/152 Yahoo group - lots of traffic there
and the 150 guys knwo their O-200s.
Larry
Emergency Procedures RD Piloting 13 April 11th 04 09:25 PM
My Engine Fire!! [email protected] Piloting 21 April 2nd 04 06:02 PM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 07:11 AM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 05:09 PM
Motorgliders and gliders in US contests Brian Case Soaring 22 September 24th 03 01:42 AM
