NMEA data from CNv to iPhone
Old July 25th 20, 12:34 AM posted to rec.aviation.soaring
Default NMEA data from CNv to iPhone
Being July 2020, what is best method to transfer NMEA data from CNv to an iPhone?
Can this be accomplished by "hard wire" or would you have to have some sort of bluetooth gadget?
Old July 25th 20, 01:18 AM posted to rec.aviation.soaring
Tango Eight
You can get NMEA data out of the CNv on the serial port. No idea what best way is to get it into an iphone.
T8
Old July 25th 20, 02:40 AM posted to rec.aviation.soaring
Stephen Szikora
It seems the only way to get data to an iPhone is using WIFI. Look for a device that converts serial to WIFI.
iPhone 5 vs iPhone 6 sunlight readability 6PK Soaring 2 March 22nd 16 11:54 PM
iGlide update for iPhone 6 (4.7 inch) and iPhone 6 plus (5.5 inch) Sean Fidler Soaring 29 March 9th 15 03:24 AM
Loading flight data to iPhone from serial port devices Craig Funston Soaring 5 July 25th 11 08:09 PM
Flight Analysis with NMEA GPS Data File jchutch Soaring 4 May 12th 08 02:26 AM
NMEA+vario+ASI data stream for WinPilot Pro Tuno Soaring 5 March 28th 07 03:02 PM
