Flight Analysis with NMEA GPS Data File
Old May 10th 08, 10:11 PM posted to rec.aviation.soaring
jchutch
Default Flight Analysis with NMEA GPS Data File
I have a handy little BlueTooth GPS logger. I can download files and
then display on GPSVisualer.com, but would love to be able to use
soaring programs to analyze in greater detail. GPSBabel does not
support icg, and programs like SeeYou do not appear to accept NMEA or
types of files generated by GPSBabel or GPSVisualizer. Given the
prevalence of NMEA as a GPS format, is there some relatively easy way
to convert or employ NMEA files in any of the soaring flight analysis
programs? Thanks.
Old May 10th 08, 10:20 PM posted to rec.aviation.soaring
nimbusgb
programs? Thanks.
try this one
http://www.softpedia.com/get/Others/...onverter.shtml
Old May 10th 08, 10:41 PM posted to rec.aviation.soaring
noel.wade
Actually, the latest versions of GPSBabel supposedly DO convert to IGC
format:
http://www.gpsbabel.org/htmldoc-1.3.5/fmt_igc.html
Enjoy!
--Noel
Old May 11th 08, 05:41 AM posted to rec.aviation.soaring
jchutch
format:
Enjoy!
--Noel
You're right! I just discovered it under FAI/IGC. Works fine.
Thanks.
Old May 12th 08, 03:26 AM posted to rec.aviation.soaring
Adam Schneider[_2_]
Not just the latest versions... GPSBabel has supported IGC files since
2004!
Adam
http://www.gpsvisualizer.com/
format:
Enjoy!
--Noel
Need GPS flight logs in NMEA format... [email protected] Soaring 6 February 15th 08 09:05 AM
JPI Engine Data Analysis Questions Jay Honeck Owning 12 December 18th 07 10:31 PM
NMEA+vario+ASI data stream for WinPilot Pro Tuno Soaring 5 March 28th 07 04:02 PM
Flight Data recorders on a 757 - What data? Al Dykes General Aviation 0 January 1st 07 06:09 PM
Polar Analysis from flight logs? Mark Zivley Soaring 87 January 13th 05 01:34 AM
