LS 4 Ballast Weights
Old August 25th 20, 04:14 AM posted to rec.aviation.soaring
kolray25
Default LS 4 Ballast Weights
Would someone please help me I want to know the dimensions and actual
individual weight of an LS4 ballast weight. I also want to know whether the
material the weights are made of. (steel or lead).
Cheers, Geoff.
Old August 26th 20, 07:15 PM posted to rec.aviation.soaring
K8
Mine are lead. They are stamped 2.45 KG. They are 5.5 cm x 2.8 cm x 14.5 cm. The mounting hole in the center is approximately 1.7 cm in diameter and the hole is threaded. I hope that helps.
Doug
Old August 28th 20, 08:50 AM posted to rec.aviation.soaring
kolray25
Doug
Hi Doug, Many thanks for the info - just what I needed.
Happy Soaring, Geoff.
Looking for a set of ASK-21 ballast weights kirk.stant Soaring 3 September 14th 15 04:36 PM
ASK-21 and Grob 103 cockpit ballast weights kirk.stant Soaring 12 September 2nd 15 08:57 PM
Grob 103 Ballast Weights Roger Fowler[_2_] Soaring 0 January 16th 12 12:18 PM
Lak-12 weights pete83 Soaring 1 June 26th 04 11:25 PM
Lak-12 weights pete83 Soaring 0 June 26th 04 06:47 PM
