LS4 Ballast Dump Valve Seats
Old September 25th 20, 05:13 AM posted to rec.aviation.soaring
Hypo Thebai
Default LS4 Ballast Dump Valve Seats
Hi;
We need to replace the dump valve seat in an LS4. This is the seat that forms the seal. The originals seem to have been made by Georg Fischer (+GF+) for a valve they no longer make. I believe that the +GF+ part number was 161 483 260. From my present understanding +GF+ cannot supply this item.
I'm hoping that somebody here will know of an alternative source.
These valves are used in a number of DG and LS gliders. Almost certainly any glider that is filled by pushing water up through the dump outlet uses this valve - e.g. DG 300, DG 505 some LS gliders. They are typically attached to ballast bags.
SZD 55 water dump valve sticking. Mark B[_2_] Soaring 0 February 1st 19 10:15 PM
Wanted: LS6-b tail dump valve [email protected][_2_] Soaring 3 August 13th 13 02:22 PM
Solenoid valve for creating a tail ballast dump system...Lak17a Sean Fidler Soaring 1 March 30th 11 02:30 PM
Solenoid valve for creating a tail ballast dump system...Lak17a Sean Fidler Soaring 3 March 28th 11 08:51 PM
Dump valve for Ls4a Robert Harvey Soaring 0 November 20th 05 08:47 PM
