Motorfalke sf25b mods to C or D
Old October 6th 20, 10:08 AM posted to rec.aviation.soaring
Neal Stephenson
Default Motorfalke sf25b mods to C or D
Good day,
Does anyone know what is required to upgrade a SF25B model to a C or D model.
Basically the requirements to increase the all up weight (MAUW). to at least the 610kg mark.
I see some of the later versions are up to 690kg.
(This will be in the experimental catergory)
Thanks in advance.
Neal
South Africa
Old October 6th 20, 11:33 AM posted to rec.aviation.soaring
Eric Munk
Scheibe TM 653-32 refers to conversion to C-model. It's only possible for
certain serial numbers and involves major work (changing the rear wing
attachments, engine mounts/engine), then standard C-model MTOW.
Scheibe TM 653-33 refers to conversion to D-model. For all serial numbers.
Major work, involving shortening of the wingspan, structural changes to the
fuselage, engine change and new prop, new fuel system, the MTOW 580 kg or
there abouts.
At 08:08 06 October 2020, Neal Stephenson wrote:
Good day,
model.
Thanks in advance.
Neal
South Africa
Old October 6th 20, 02:26 PM posted to rec.aviation.soaring
Neal Stephenson
Thanks Eric,
would you know where I could get a copy of the technical Manual that would detail this changes that are required.
We have the expertise here in South Africa, but would like to follow the Schiebe modifications to the book!
Thank you so far.
there abouts.
Good day,
model.
Thanks in advance.
Neal
South Africa
Old October 6th 20, 08:48 PM posted to rec.aviation.soaring
Eric Munk
Both are available as downloads from the Tc holder’s website.
Scheibe-aircraft.de
At 12:26 06 October 2020, Neal Stephenson wrote:
Thanks Eric,
that would
follow the
Thank you so far.
possible for
rear wing
MTOW.
serial
numbers.
changes to
MTOW 580 kg or
there abouts.
Good day,
model to a C or D
model.
(MAUW). to at
Thanks in advance.
Neal
South Africa
Slingsby T.61 MotorFalke R. Wubben Soaring 11 December 10th 17 08:38 PM
Scheibe SF-25 Motorfalke horizontal stabilizer and other parts needed [email protected] Soaring 7 January 25th 17 06:51 PM
AS-W12 Mods Steve Leonard[_2_] Soaring 2 May 12th 12 06:48 PM
Ka-6CR and E Canopy Mods. Robert Buck Soaring 12 March 6th 09 05:13 AM
Spot, Mods!!!! NW_Pilot Owning 0 June 22nd 08 02:46 AM
