Pre-buy after Annual
Old May 21st 05, 12:38 PM
Douglas Olson
Default Pre-buy after Annual
Newcomer to group and ownership here. Hope this isn't an FAQ, but Googling
the keywords brings up too many hits that don't address my question.
I'm looking at a fairly typical first plane to buy ... 1960s Cherokee ...
that appears to be just right. It has reasonable airframe time and low
engine time. It was annualled two months ago.
My specific question is ... Since the plane was just annualled, what should
I look for in my (free, amatuer) pre-buy and ask the mechanic too look for
in the professional inspection, that would indicate a "don't buy" decision,
even if the annual is fresh.
I'm thinking about things like interior wing corrosion that are airworthy
this year and probably next, but would make the plane a poor long-term
investment.
Is this the right question to ask? Experienced, non-monetarily motivated
answers appreciated.
Old May 21st 05, 12:49 PM
Dan Thompson
That is the right question to ask. What you are looking for are
deal-breakers, not routine maintenance items that have popped up in the two
months since the annual.
Corrosion, un-logged damage history, weak cylinders, cracked engine case,
inop accessories, nonconformance with the type certificate, missing logs,
are the types of deal-breakers that should be looked for in a pre-buy.
"Douglas Olson" wrote in message
ink.net...
Googling
should
decision,
investment.
Old May 22nd 05, 04:30 AM
Blanche Cohen
Go to the FAA website and get the list of all the applicable ADs. If
you're going to be an owner, you may as well learn to read ADs. Then
you can review the log books for compliance with the ADs.
Get an A&P (or A&P/IA) that has not worked on the aircraft to do
the pre-buy.
Decide what will be 1) a deal breaker 2) negotiable.
When I bought my cherokee I found an AD that hadn't been complied
with (the previous owner was an A&P, too!). So the cost of complying
was part of the purchase price.
Have fuN!
Old May 21st 05, 01:56 PM
dave
Doug,
Be careful about the overhaul. Low time is not always good. I looked
at one airplane that had only 600SMOH but the overhaul had been done 25
years earlier. Not only is that bad in terms of low annual usuage, it's
also way beyond Lycoming's recommendation of 12 years between overhauls.
Most sellers and brokers I spoke to refused to consider anything but
engine hours in terms of valuing the engine but calender time is
significant. There are many aircraft for sale that are within the
manufacturer's recommendations regarding hours but way beyond the 12
year recommendation. Have an experienced mechanic check the engine
thoroughly. Get an oil sample to a lab and the screen and/or filter
inspected. If possible, try to make sure the engine has at least 10 or
20 hours since the last oil change.
Dave
68 7ECA
investment.
Old May 21st 05, 02:16 PM
Doug
Your mechanic should give it a compression test, look for AD's, cut the
oil filter, sample the oil, look for corrosion. You should be able to
check the paint, upholstry, cleanliness, avionics and flight
characteristics.
As for old engines, even with low engine time, don't expect an old
engine (over 12 years) to make it to TBO. Frequently flown is MUCH
better. Frequently flown engines make it PAST TBO (frequent being over
100 hours a year, spread out through out the year).
Old May 21st 05, 03:38 PM
Mike Rapoport
Well, you could do anything from nothing to another annual. How well do you
trust the shop that did the annual? If the plane is for sale now then you
can be almost certain that the minimal amount of work was done at the
annual. As always you have to weigh the amount to spend on the inspection
against what will be found that the seller will be willing to repair.
MU-2
ink.net...
Googling
should
decision,
investment.
Old May 21st 05, 04:57 PM
Juan Jimenez
I disagree with what has been said here, except Mike. The pre-buy should be
another annual inspection, with great emphasis on known problems with the
model of aircraft you want to buy. If it was annualled two months ago with
the intention to buy, _assume_ that corners were cut. Remember, you _will_
be stuck with whatever you don't find in the pre-buy.
ink.net...
Googling
should
decision,
investment.
Old May 21st 05, 05:05 PM
Jack Allison
Hi Doug. Great question. I'm a new owner and went through a similar
experience. We bought an Arrow that had literally come out of annual a
couple of days before we showed up to take a look (and hopefully close
the deal and fly home...which we wound up doing). I poked around for
info. on the shop that had been doing the maintenance and received
positive reports (thanks again Blanche). We also asked tons of
questions to the owner and to the A&P that had been maintaining the
plane. We went through AOPA for the title search and copies of past
paperwork. Everything looked fine so we put down a deposit and headed
to Denver. I spend a couple hours with the A&P reviewing the logs and
asking more questions. I also had a chance to fly the plane as well.
Reviewing the logs, we just kept finding more information that the plane
had been well maintained. The A&P let me do whatever I wanted in terms
of poking around the plane.
The next day, one partner along with an instructor showed up. They had
a look at the plane and we closed the deal then flew home. So, our
pre-buy inspection was very limited. We could have (and many would say
"should have") had a different shop do some form of pre-buy inspection.
Given how the entire deal was progressing and our overall timeframe,
we opted not to take the plane to another shop. A definite risk but one
that we were comfortable with given all of the information we had.
Specifically on your situation, check into whether or not Piper service
bulletin 1006 has been performed. This is the one where they pull the
tanks and check for corrosion on the wing spar caps. Many Piper owners
advised me this is a "must have". If it has not been performed, I feel
it is worth spending the money to do as part of a pre-buy inspection.
Good luck with the purchase process. Be prepared to walk away if
something doesn't feel right. We had to walk away from two deals before
we found our Arrow. Not fun, time consuming, etc...but worth it in the end.
Jack Allison
PP-ASEL-IA Student
Arrow N2104T
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Old May 24th 05, 12:01 AM
service
owners
feel
I'll second Jack's advice on this one. The only way to detect
corrosion in that area is to perform SB #1006. That area is not
normally inspected as part of an annual inspection. If it hasn't been
performed, the long term condition of the plane is a question mark. It
could be fine (as in most cases), or it could have some intergranular
corrosion of the spar which will render your wings basically useless.
Inspecting for corrosion is key to the long term investment prospects
of an airplane. On a Cherokee group that I frequent, one owner is
currently disassembling his recently bought plane and selling the
pieces. His first annual uncovered massive corrosion under the front
floorboards that would not have been economically feasable to repair.
Old May 24th 05, 01:14 AM
Yes indeed, SB 1006 is a "must do" as far as I'm concerned. If I was
considering purchase of an older PA-28 I would check the logs to verify
compliance. If it hadn't yet been done, I would make successful compliance
part of any purchase agreement. An A&P familiar with the SB, and that
should be any A&P familiar with PA-28s, should be able to pull off the
inspection in a few hours. Most of the work entails removal and replacement
of the many screws holding the tanks in place, and that part can be done by
anybody.
BTW, when SB 106 is done the fuel lines behind the tanks should be routinely
replaced, as should the fuel gauge senders if they are giving any problems.
None of that is mentioned in the SB, but if the lines are more than 10 years
old it would be dumb not to take advantage of having the tanks off as an
opportunity to replace them. The lines themselves don't cost that much.
How to deal with the inspection as part of a purchase deal? As a buyer, I
would offer this: If the inspection shows either no corrosion or minor,
easily corrected corrosion, I buy the plane at the agreed price and pay for
the inspection (and fuel line replacements). If major corrosion is found
(requiring more than, say, $200 to correct) then the deal is off and I owe
nothing.
-Elliott Drucker
Christmas Annual - long drivel Denny Owning 23 December 31st 04 08:52 PM
My Aztec's first Annual Louis L. Perley III Owning 11 November 11th 04 05:04 AM
Annual Report Final. "Long" NW_PILOT Owning 20 October 28th 04 07:20 PM
Annual Report Final. "Long" NW_PILOT Piloting 22 October 28th 04 07:20 PM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 03:41 PM
