currency question
Old May 30th 05, 02:20 AM
Default currency question
Have you ever "made up" an approach to a nonexistent airport for the
purposes of training or currency? I mean, to pick a space in the
boonies, and then use nearby navaids to fashion a homemade approach to
an imaginary runway. Some instructors will do this.
Now, I was wondering, is there any way flying such an "approach" could
be loggable towards instrument currency?
(obviously, under the hood, VFR, with a safety pilot. You'd be insane
and illegal to try this with real IMC)
The advantages this could provide are mostly convenience (not having to
deal with the traffic-related delays associated with an approach to a
real airport with real controllers) and also variety -- you could fly
flavors of approaches that aren't available near where you live.
What do you guys thing?
-- dave j
61.57(c)(1):
(c) Instrument experience. Except as provided in paragraph (e) of this
section, no person may act as pilot in command under IFR or in weather
conditions less than the minimums prescribed for VFR, unless within the
preceding 6 calendar months, that person has:
(1) For the purpose of obtaining instrument experience in an aircraft
(other than a glider), performed and logged under actual or simulated
instrument conditions, either in flight in the appropriate category of
aircraft for the instrument privileges sought or in a flight simulator
or flight training device that is representative of the aircraft
category for the instrument privileges sought-
(i) At least six instrument approaches;
(ii) Holding procedures; and
(iii) Intercepting and tracking courses through the use of navigation
systems.
Old May 30th 05, 02:35 AM
Bob Gardner
Only got nine hits when I searched my Summit Aviation CD of all FAA pubs,
and every hit implied a published approach. I doubt that the regulations
writers ever contemplated that someone would consider an unpublished
approach to have any legal standing. How would you comply with 61.51(g),
which requires that the location and type of each approach be logged?
Logging "PAE ILS 16" looks a lot better than "Podunk VOR approach" when
Podunk doesn't have any approaches at all.
If these home-made approaches were based on a navaid that is a part of a
published approach, I would be concerned about IFR traffic using the same
airspace...although "out in the boonies" makes that unlikely. IOW, I do not
consider the practice to be practical.
Bob Gardner
-- dave j
61.57(c)(1):
systems.
Old May 30th 05, 02:46 AM
Thanks Bob and Roy, this is what I figured, but it was worth a try. I
assume that this also applies to airways and holds, then. That is, real
victor airways and real holds (which I guess would be holds published
on charts or approach plates, or designed and assigned on the fly by a
real controller.)
-- dave j
Old May 30th 05, 03:01 AM
Ooh, I'm going to follow up my own post. Obviously, intercepting
courses does not mean V airways, so anywhere you're going is fine as
long as you use a "navigation system."
And holding procedures is probably the same.
-- dave j
Old May 30th 05, 05:49 AM
Doug
When I was an instrument student, I made up an approach to an airport
that did not have any approaches. It was a circle to land. I even made
an approach plate on the same size paper as the govt charts and put
every little number and detail on it. It was an interesting exercise. I
then went out and flew it (in VFR conditions), and flew the missed.
I see no reason to use it for currency, might as well use a real
approach as these familiarize you with an approach you might use in IMC
someday. Familiar approaches are easier for me to fly.
Old May 30th 05, 12:19 PM
Brad Zeigler
I have drawn up a approach that I use for instrument training that includes
a DME arc because no such approach is conveniently available. I have also
used published approaches but added 1000 feet to minimums for training
purposes when the destination airport was busy. In both cases, I consider
them training exercises but do not include for currency purposes.
-- dave j
61.57(c)(1):
systems.
182RG question Paul Anton Owning 11 May 16th 05 09:45 PM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 12:14 AM
