Best VHF Antenna
Old December 6th 04, 05:46 PM
Steve
Default Best VHF Antenna
Any comment on which style COM antenna works best on a tube and fabric
aircraft connected to a junction of tubes?
Old December 6th 04, 06:21 PM
its best to install a grounding plan on your aircraft, then install ant
on grounding plan
Old December 6th 04, 07:04 PM
on grounding plan
Old December 6th 04, 07:05 PM
RST Engineering
The AV-529 (Miller) has been the standard for the last 30 years. I believe
Comant makes a similar device called the 121 as I vaguely recall. They are
both right around $100, which knowing what is inside is a ripoff, but that's
the way it goes.
"Steve" wrote in message
m...
Old December 7th 04, 04:05 AM
believe
They are
that's
the way it goes.
m...
fabric
Old December 7th 04, 04:09 AM
Can the AV-529 be mounted to the bottom of the aircraft or should I go
with the AV-17? Is the AV-17 as good as the AV-529
Old January 25th 05, 03:04 PM
Jean-Paul Roy
There is also a very good antenna called the Miracle air whip.
see it at: http://www.miracleantenna.com
Hope this helps
Jean-Paul
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 07:59 PM
Another antenna question David Wilson Home Built 7 August 12th 04 11:04 PM
Antenna ground plane and coax grounding G. Fred McCutchen Home Built 2 August 8th 04 01:27 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 04:27 PM
comm's RX antenna acepilot Home Built 5 March 3rd 04 06:34 PM
