Turbo Lance MP flux ?
Old September 27th 05, 05:06 AM
John Doe
Default Turbo Lance MP flux ?
I've been looking to buy a turbo lance and I've demo'd two of them so far.
One I flew was rock solid, but the second one the engine would not hold a
solid MP. It would flucuate +/- an inch or so especially on take off. We
even got the overboost light just off the end of the runway.
After seeing that, I am pretty concerned about the turbo system on the
lance.
has anyone else seen this problem? Was it just that plane or more of a turbo
problem that I would have with any lance?
Old September 27th 05, 04:29 PM
Mike Rapoport
Did it fluctuate or just rise an inch or two and then stay? The wastegate
is manual so it isn't moving unless you are moving the throttle. You
should be adding throttle until you get about 2-3"MP below where you want to
be for takeoff. As the exhaust path heats up and the "bootstrapping"
subsides the MP will stabilize
MU-2
"John Doe" wrote in message
news:IG2_e.27708$8q.271@lakeread01...
lance.
turbo problem that I would have with any lance?
Old September 28th 05, 12:30 AM
John Doe
. net...
to be for takeoff. As the exhaust path heats up and the "bootstrapping"
Good question, Its been a month since I've flown that one. I'll have to go
back and fly it again. I'll let you know.
Thanks.
Old September 28th 05, 02:56 AM
Mike Rapoport
Like anything else, you will get used to this if you buy the airplane.
MU-2
news:YJj_e.27941$8q.5517@lakeread01...
. net...
wastegate is manual so it isn't moving unless you are moving the
throttle. You should be adding throttle until you get about 2-3"MP
below where you want to be for takeoff. As the exhaust path heats up and
the "bootstrapping" subsides the MP will stabilize
go back and fly it again. I'll let you know.
Thanks.
Turbo Lance empty weight John Doe Owning 3 September 1st 05 05:56 PM
Turbo Lance II opinions John Doe Owning 25 August 30th 05 03:14 PM
Why turbo normalizer? Robert M. Gary Piloting 61 May 20th 05 05:33 PM
FS: Duo Discus Turbo - Texas, USA Mark Zivley Soaring 2 May 5th 05 12:34 AM
Piper Lance Renee Purner Owning 22 November 4th 03 08:47 PM
