Cherokee 140 Carb Heat Cable Issue
Old October 22nd 05, 03:13 AM
ParaPants
Default Cherokee 140 Carb Heat Cable Issue
Hello,
I have a Cherokee 140, and I think the carb heat cable is not connected
to the handle on the pannel correctly. I have a handle that moves up
and down (not push/pull). Currently the cable was put through the
whole on the back of the lever and bent around it. Shouldn't their be
a connection something like their is on the airbox handle side of the
cable?
Scott Taylor
N8030N
Old October 22nd 05, 11:27 PM
John Kunkel
"ParaPants" wrote in message
Hello,
cable?
The cockpit end of the cable should have a threaded end, the cable end
should be threaded into a clevis and attached to the lever with a screw,
castellated nut and cotter pin.
Sounds like the cable end broke and was jury-rigged.
Have you ever experienced carb ice with an injector carb? flybynightkarmarepair Home Built 1 January 31st 05 02:48 AM
Carb heat specs? Rich S. Home Built 2 November 13th 04 05:39 PM
alternate carb heat Ray Toews Home Built 16 October 29th 04 01:41 PM
Painting and air cooled motor? CitizenX Home Built 5 June 30th 04 01:47 PM
Rudder cable - was The Little Wheel in Back BD5ER Home Built 9 September 11th 03 05:14 PM
