VG's on Warrior?
Old November 7th 05, 12:05 AM
Dave
Default VG's on Warrior?
OK, after a lot of research, we are looking at installing AMR&D's
Vortex Generators on our Warrior..
Anybody out there with expirence with these?
Dave
Old November 7th 05, 02:56 AM
zatatime
On Sun, 06 Nov 2005 20:05:50 -0400, Dave
Dave
Why did you decide you wanted to do this?
z
Old November 7th 05, 05:07 AM
Ben Hallert
I'll go out on a limb and guess it's because of one of these stated
benefits from pipermods.com:
" # LOWER STALL 5 mph
# IMPROVE LOW SPEED HANDLING
# IMPROVE SHORT FIELD PERFORMANCE
# IMPROVE PERFORMANCE AT GROSS WEIGHT
# IMPROVE CRUISE 3 - 7 mph
# INCREASE IN TOP SPEED"
If you're familiar with the reasons someone might want to buy them
(considering your past posts, I know you are) but have knowledge about
why it would be a bad idea or doesn't do what it claims, then, with
respect, why be a jerk about it? Just tell us why it's dumb already
without stringing us along. I'm hoping to buy a Warrior II soon
myself, and I'm studying all the mods to see what flies and what dies.
Thanks!
Ben Hallert
PP-ASEL
Old November 7th 05, 03:45 PM
Newps
You cannot lower stall and increase cruise with one mod, pure hype.
VG's do lower stall. I had them on my 182 and have them now on my
Bonanza. They lower the stall about 3-5 mph on my Bo. You will lose a
little cruise speed and top speed, aprrox 3-5 mph. If they didn't lower
cruise what they're really saying is that they don't add any drag. If
they didn't add drag you wouldn't have to glue them on, they'd just sit
there. As for the low speed handling and gross weight performance that
is subjective. I have 1000 hours in 182's and could never tell any
difference in flying qualities. One thing you will notice is that if
you were to go to altitude and get into a power off 45 degree bank, full
back stick turn. When the airplane stalls if you do not have VG's the
plane will always roll to the high wing side. With VG's the plane does
not roll at all but simply descends at approx 1500 fpm. Having said all
that there's no reason to put them on a Warrior. The Warrior has no
performance to start with. All you would succeed in doing is to slow
yourself down.
Old November 7th 05, 04:12 PM
xyzzy
You cannot lower stall and increase cruise with one mod, pure hype. VG's
do lower stall. I had them on my 182 and have them now on my Bonanza.
They lower the stall about 3-5 mph on my Bo. You will lose a little
cruise speed and top speed, aprrox 3-5 mph. If they didn't lower cruise
what they're really saying is that they don't add any drag. If they
yourself down.
If VG's are really only to improve stall characteristics, they don't
seem worth it in this case because Warriors already have pretty benign
stall characteristics.
"You can support the troops but not the president"
--Representative Tom Delay (R-TX), during the Kosovo war.
Old November 7th 05, 04:39 PM
Newps wrote:
: performance to start with. All you would succeed in doing is to slow
: yourself down.
You may want to keep an open mind on this. There are experimentally
documented cases where VGs not only decrease stall speeds, but also increase cruise
speed. Doesn't seem intuitive to go faster by adding draggy looking things, but it
turns out the more laminar airflow they provide decreases drag by more than what they
add.
-Cory
* Cory Papenfuss *
Old November 8th 05, 12:07 AM
zatatime
On 6 Nov 2005 21:07:02 -0800, "Ben Hallert"
Thanks!
Ben Hallert
PP-ASEL
Sorry you felt I was being a jerk. On the contrary I was looking to
learn something. I definitely have my opinions on VGs but have never
heard of anyone putting them on a Cherokee. With a big, fat, short
wing I was interested to see what it would do for the airfoil from
personal experience of others. Luckily others responded in a way that
provided me greater knowledge (thanks).
In case you missed the posts, it looks like for a Warrior II they
won't help much because Piper had already "fixed" the wing to some
degree so they might not benefit you. In my opinion, flap gap and
aileron seals would be where'd I'd put my money first. They should
lower the stall speed, increase low speed handling, and provide a
slightly higher cruise (2-3 kts); and I wouldn't have funny looking
things stuck all over my wings that would fall off over time.
Having said that, I'm also familiar with the wing root problems on
older Cherokees (which is what I own). It sounds like VGs could help
that somewhat so some additional investigation may be warranted.
Is it possible to put like 4 or 5 on each side, just to compensate for
the turbulent air at the wing root?
Thanks to those contributing to this thread.
z
Old November 8th 05, 03:04 AM
Dave
Hi Z!
To clarify.
There are only 4 per side, between the fuel tank and the fuselage,
maybe one more.. (from the pictures)
Piper fixed the outer (tapered) portion of the wing, but the inner
portion is "plain old Cherokee" (on a Warrior)
Dave
Thanks!
Ben Hallert
PP-ASEL
z
Warrior cruise RPM settings lardsoup Piloting 35 October 9th 05 11:59 PM
Flying to Cancun from KeyWest in a Warrior. Piperflyer Piloting 6 September 29th 04 07:26 AM
Fuel dip tube for Piper Warrior? TTA Cherokee Driver Owning 16 May 3rd 04 05:42 PM
Warrior POH Michael Egan Owning 2 February 4th 04 05:41 PM
Landing a warrior Dan Moos Piloting 27 August 17th 03 11:05 PM
