Wake Turbulence behind an A-380
Old November 22nd 05, 10:24 PM posted to rec.aviation.piloting
Default Wake Turbulence behind an A-380
Yee-hah! Don't get too close to this whale...
Change in Rules
Needed for Wake
Of Big New Jet
By ANDY PASZTOR and DANIEL MICHAELS
Staff Reporters of THE WALL STREET JOURNAL
November 22, 2005; Page B1
Airliners may have to fly twice the normal distance behind the new
Airbus A380 superjumbo jet to avoid potential hazards from its
unusually powerful wake, according to preliminary safety guidelines.
The standards released to the industry by the International Civil
Aviation Organization earlier this month are tentative and almost
certainly more cautious than the formal rules expected next year. But
if the final air-traffic procedures end up close to ICAO's initial
proposal, they could undermine one of Airbus' top selling points for
the largest passenger plane ever built: greater efficiency at congested
hub airports.
Interim air-traffic control guidance from ICAO says the mammoth plane,
scheduled to go into service next year, produces "significantly
stronger" air turbulence than the largest jetliners now in use. Because
flight tests and data analyses "have raised concerns" about potential
safety issues, according to the guidance, it calls for minimum
separations of 10 nautical miles for all aircraft following a landing
A380, versus the typical five-mile mandatory buffer behind today's
largest aircraft.
For aircraft flying the same route directly behind an A380 at cruising
altitude, the recommended minimum spacing is tripled to 15 nautical
miles.
The interim rules are "very conservative" and will remain effective
"until conclusive guidance is issued mid-next year," said Paul Wilson,
a senior European air-traffic control official who is helping lead the
study. Initial plans called for the effort to be completed around
January, but now "there's a feeling more work needs to be done," Mr.
Wilson said yesterday in an interview. "What we want to do is get it
right" and rely on hard data, he added, because "we are leading the way
for all future aircraft" operating criteria.
The ICAO is a global aviation regulator whose standards and rules are
almost always accepted by individual governments.
Airbus, which touts the 555-seat A380 as "the economical solution for
heavily traveled routes," has sold it as a way to carry more traffic
without adding aircraft. The twin-deck jetliner can carry at least 35%
more passengers than Boeing Co.'s largest model, the 747-400. In some
configurations, the plane can handle more than 850 passengers.
The preliminary rules are already grabbing notice from Airbus
customers. A spokesman for Germany's Lufthansa, which has ordered 15
A380s, said "it is crucial for us that the separation is the same as
for a 747" because "we operate at congested airports."
The two-page ICAO advisory not only deals with the safety aspects of
air turbulence at low altitudes near airports but even raises questions
about potential hazards for nearby aircraft in midflight. The guidance
says the so-called wake vortices produced by the A380 -- twin cones of
turbulent air fanning out from its wingtips -- "will descend further
and be significantly stronger" than those from other large jets,
potentially even affecting jets traveling in the opposite direction
some 2,000 feet below. "Because it has not yet been possible to
establish the level of hazard" from such turbulence, the guidance
recommends "offset tracks or additional vertical spacing" for added
protection.
When an airborne aircraft runs into such turbulence, the impact can
jostle the trailing plane. In extreme circumstances, the result can
even be loss of control, though there haven't been any recent crashes
of jetliners attributed primarily to such encounters. Many years ago
the U.S. Federal Aviation Administration had to lengthen spacing
requirements for planes flying behind Boeing 757 jetliners, following a
fatal crash of a business jet that ran into a 757's wake.
Airbus has said the four-engine plane, with a maximum takeoff weight in
excess of a million pounds, is designed to fit seamlessly into
air-traffic systems world-wide without requiring greater spacing than
existing models or needing any other special handling by controllers.
An Airbus A380 marketing brochure in 2003, for example, said: "there is
no need to introduce any changes in separation standards" for the A380
because the aircraft's wake "is similar to that of the 747-400."
A spokesman for Airbus, which is owned 80% by European Aeronautic
Defence & Space Co. and 20% by Britain's BAE Systems PLC, declined to
comment, citing the ongoing studies. Despite the success Airbus has had
using computers to precisely predict handling and other characteristics
of the new plane, "we are still in the Stone Age for modeling" wake
turbulence, said Robert Lafontan, the A380's chief engineer, in an
interview several weeks ago.
The interim guidelines also recommend an additional wait of one minute
-- on top of today's typical two-minute spacing -- for smaller
jetliners taking off directly behind the giant A380. Once the A380
reaches cruising altitude, the guidance suggests that on "rare
occasions" its wake may be strong enough to shake planes flying nearly
half a mile below it and end up creating a "comfort issue" for
passengers in those jets.
With less than 160 orders and commitments for the A380, Airbus needs
about 90 more to break even. But the market is becoming more
competitive with Boeing's announcement that it is offering a larger 747
version.
The FAA, while particularly sensitive about any perception that it is
discriminating against the European planemaker, has been quietly
pushing for additional testing and more restrictive rules, industry
officials say. At the beginning of the year, an internal FAA report
projected that the A380's wake may result in fewer arrivals at some
airports; that the plane may require extra time or distance to execute
a missed approach to a runway; and it "may have an adverse impact" on
general airport operations. Air-traffic control officials, the report
concluded, are "uncomfortable" with the A380 and need answers quickly.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 22nd 05, 10:29 PM posted to rec.aviation.piloting
snip
Airbus should include color smoke generators off each wingtip to colorize
the vortices and give VFR aircraft something visually to avoid.
Peter
Old November 22nd 05, 11:42 PM posted to rec.aviation.piloting
Change in Rules
Needed for Wake
Of Big New Jet
hub airports.
largest aircraft.
And this is a surprise? Did they think an airplane that size would have
the wake turbulence of a 737?
Matt
Old November 23rd 05, 04:19 AM posted to rec.aviation.piloting
Not a 737, but Airbus was claiming it would be comparable to a 747, which is
a "heavy" aircraft. If you read the article, you might have noted that
"An Airbus A380 marketing brochure in 2003, for example, said: "there is
because the aircraft's wake "is similar to that of the 747-400.""
Old November 23rd 05, 04:20 AM posted to rec.aviation.piloting
snip
And other IFR aircraft, including jets, for that matter.
Old November 23rd 05, 06:30 AM posted to rec.aviation.piloting
"Peter R." wrote in message
snip
Different color smoke from each wingtip would be very pretty.
Old November 23rd 05, 12:14 PM posted to rec.aviation.piloting
I missed that part. Shame on Airbus then. Either they really believed
this and are thus stupid, or they were outright being deceptive.
I can't believe that their customers actually believed that though.
That is pretty amazing as well.
Matt
Old November 23rd 05, 01:20 PM posted to rec.aviation.piloting
Matt,
BS! I strongly suggest you read that report again. Nowhere does it say the
wake turbulence measurements have been completed and/or published. These
are "tentative" and "over-cautious" preliminary/interim standards issued
by ICAO as a suggestion. No one knows what wake turbulunce is causes - and
we will know before final ruling.
The problem is: The A380 is flying around as we speak, so ATC has to have
some guidance right now. That's what this does. It says NOTHING about the
actual wake turbulence caused.
But, anything for some cheap shots at Airbus, right?
Thomas Borchert (EDDH)
Old November 23rd 05, 02:25 PM posted to rec.aviation.piloting
by "Matt Barrow" Nov 22, 2005 at 11:30 PM
snip
colorize
That would be cool, just like the stunt pilots' planes. Those jets would
look very cool doing hammerheads and loops to entertain the passengers and
crowds below.
Old November 23rd 05, 02:32 PM posted to rec.aviation.piloting
Here here!
The fact is that when Boeing launched the 747, the separation had to be
changed. No one seemed to mind to much that that happened at the time -
probably because of increased passenger volume.
With that in mind, what makes you think that airlines are going to mind too
much if the separation behind a 380 has to be increased? If the airbus
carries twice as many passengers, that effectively means less Boeings in the
sky and if there is less requirement for Boeings that means less a/c
pollution, more efficient ATC, and safer flying!
I shouldn't be cheering just yet if I were you...
G
Turbulence Marco Rispoli Piloting 19 October 17th 04 06:53 AM
Wake Turbulence Question HankPilot2002 Piloting 11 July 14th 04 04:49 AM
caution - wake turbulence John Harlow Piloting 1 June 4th 04 04:40 PM
Wake turbulence avoidance and ATC Peter R. Piloting 24 December 20th 03 11:40 AM
How much turbulence is too much? Marty Ross Instrument Flight Rules 8 August 21st 03 05:30 PM
