Last week I found the baffle on our left engine's #6 cylinder had broken the
bracket off the bottom of the baffle. The bracket holds a long skinny tension/stabilizer rod between the #6 cylinder baffle and the #2 cylinder baffle. From what I can tell, the bracket simply needs to be rivited back on to the baffle, however the baffle will have to be removed to accomplish this. I have yet to pull the top cowl so I can actually see how the baffle is attached. Does anybody have any experience removing this particular baffle? I'm sure it would have to be removed before the #6 cylinder could be pulled. Any thoughts are appreciated. Jim |
Get somebody who does a lot of his own maintenance to help you - and
who has some rivets, aluminum, and tools... This is not rocket science... Easily done with common sense and a little show-n-tell from others... denny |
Just what I wanted to hear.
Thanks Denny. Jim "Denny" wrote in message oups.com... Get somebody who does a lot of his own maintenance to help you - and who has some rivets, aluminum, and tools... This is not rocket science... Easily done with common sense and a little show-n-tell from others... denny |
De-ice boot repair | gbessert | Owning | 3 | August 29th 17 07:30 PM |
Dittel Radio Repair | [email protected] | Soaring | 4 | July 22nd 05 12:02 PM |
Calibrate? Repair? Adjust? | RST Engineering | Owning | 3 | April 4th 05 01:41 PM |
Advised on FAA Repair Station outside USA | tbm700 | Owning | 0 | September 23rd 04 05:50 PM |
Canopy crack repair | Pete Brown | Soaring | 0 | May 18th 04 03:09 AM |
