GEL-GLOSS cleaner?
Old January 21st 06, 10:40 PM posted to rec.aviation.owning
Default GEL-GLOSS cleaner?
Has anyone had any experience with GEL-GLOSS cleaner on their plane? I
think they sell it at Lowe's and some other stores.
Some guy during the standard rainy afternoon hangar talk said he uses it on
his plane and it works great as a cleaner and is much cheaper than aviation
cleaner.
Any thoughts from anyone?
Thanks.
Old January 22nd 06, 12:02 AM posted to rec.aviation.owning
"John Doe" wrote in message
ink.net...
on his plane and it works great as a cleaner and is much cheaper than
aviation cleaner.
Thanks.
Some marine gel coat cleaners are very abrasive. Don't know about the
product you are talking about but I would be careful. It might clean well
at the cost of rapidly grinding away your paint. Gel coats are much thicker
than paint.
Old January 22nd 06, 02:17 AM posted to rec.aviation.owning
"JD" == John Doe writes:
JD Some guy during the standard rainy afternoon hangar talk said
JD he uses it on his plane and it works great as a cleaner and is
JD much cheaper than aviation cleaner.
JD Any thoughts from anyone?
Well, yes.
I wouldn't use any non-aviation cleaner on an airplane. They surely
aren't tested for aircraft or aluminum and might well end up corroding
your plane.
Simple Green Aircraft Cleaner Dan Luke Owning 8 August 3rd 05 12:49 AM
Upholstery Cleaner? Alan Bloom Owning 3 August 20th 04 11:17 PM
Oil/Bug cleaner tony roberts Owning 3 June 2nd 04 01:28 AM
Plexiglas cleaner/ polish eddie Owning 9 August 1st 03 12:59 AM
Wing cleaner Viperdoc Owning 27 July 15th 03 05:03 PM
