Pitot Heat Failure in a Piper
Old February 2nd 06, 04:59 PM posted to rec.aviation.owning
Default Pitot Heat Failure in a Piper
I have a 1978 Warrior II and it looks like the heat element went south. The
circuit breaker is fine so I believe that's the problem but I'm open to
suggestions. My A&P is out of town so I'd like to try and get a head start
by ordering parts if possible. Can anyone recommend a source to get a
heating element for a Piper pitot tube? Is it recommended to get that
separately or is a new pitot unit the way to go?
Marco
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old February 2nd 06, 05:41 PM posted to rec.aviation.owning
I would check the switch first, relatively cheap. Had the same problem. At
first it wouldn't blow the circuit breaker, it simply wouldn't warm up.
After we started checking wires and connections, we found the switch was
bad. After we played with the switch, the circuit breaker would blow.
"Marco Leon" mmleon(at)yahoo.com wrote in message
The
Marco
Old February 2nd 06, 06:25 PM posted to rec.aviation.owning
In my Warrior it was broken wires at the pitot. The avionics shop
noticed it during the 24 mo. certification. Easily corrected for no
more cost than connector and shop time.
RK Henry
On Thu, 2 Feb 2006 11:41:29 -0600, "Jim Burns"
The
Marco
Old February 2nd 06, 07:43 PM posted to rec.aviation.owning
Marco, You can have them repaired at airparts of lock haven. They did
mine a few yrs. ago.@100 bucks... quick turn around time....
I would check for power out at the pitot tube first though.
http://www.airpartsoflockhaven.com/
RK Henry
The
Marco
Old February 2nd 06, 07:58 PM posted to rec.aviation.owning
Thanks for the info. Nice website. It looks like checking the wiring is the
prudent way to go before I order anything. Oh well, I guess it's gonna be a
VFR trip this weekend.
Marco
"joe" wrote in message
RK Henry
problem. At
was
south.
The
to
start
Marco
Old February 3rd 06, 02:34 AM posted to rec.aviation.owning
My guess is that it is not the heating element. I had the same thing happen
on a Sundowner. I went ahead and ordered the part after the avionics tech
who was doing the IFR cert assured me it was the element. My A&P tested the
old one after he took the $450.00 new part out of the box and installed it.
The old one was fine, it turned out it was the ground wire in the wing. He
said he threw it in a bucket he has of old, functional heated pitot tubes.
Marco
Old February 3rd 06, 02:46 AM posted to rec.aviation.owning
("LWG" wrote)
[snip]
My A&P tested the old one after he took the $450.00 new part out of the
box and installed it. The old one was fine, it turned out it was the
ground wire in the wing. He said he threw it in a bucket he has of old,
It's like those Capital One credit card commercial - NO! NO! NO! NO! NO!
The answer is always ...."The ground!"
(Doesn't it seem like that's the case sometimes?)
Montblack
Old February 3rd 06, 03:50 PM posted to rec.aviation.owning
Marco Leon mmleon(at)yahoo.com wrote:
: I have a 1978 Warrior II and it looks like the heat element went south. The
: circuit breaker is fine so I believe that's the problem but I'm open to
: suggestions. My A&P is out of town so I'd like to try and get a head start
: by ordering parts if possible. Can anyone recommend a source to get a
: heating element for a Piper pitot tube? Is it recommended to get that
: separately or is a new pitot unit the way to go?
The heating elements - there are 2 in the pitot tube - are supposedly
not repairable. I had one bad heating element a few years ago and a
new heated pitot tube from DMFS was "only" about $250. If the pitot tube
is replaced you are supposed to re-do the transponder/IFR cal as you are
"opening the static system".
Aaron C.
Old February 3rd 06, 04:42 PM posted to rec.aviation.owning
Aaron Coolidge wrote:
: The heating elements - there are 2 in the pitot tube - are supposedly
: not repairable. I had one bad heating element a few years ago and a
: new heated pitot tube from DMFS was "only" about $250. If the pitot tube
: is replaced you are supposed to re-do the transponder/IFR cal as you are
: "opening the static system".
Supposed to be, perhaps. When we upgraded to a heated pitot on our PA28, we
bought a salvage one with dead heaters. I forget where we bought replacement heaters,
but they basically slid out and slid in new ones. They were pretty pricey for what
they were ($100 for the two comes to mind). If necessary I can try to look up where I
got them, but I'd agree a wiring troubleshoot is in order first.
-Cory
* Cory Papenfuss *
Old February 4th 06, 02:30 PM posted to rec.aviation.owning
"Aaron Coolidge" wrote in message
After working on the static system, all you need to do is check for leaks.
An airframe mechanic can perform the check and recertify the static system.
Pump the static system until the altimeter reads 1000' above field elevation
and check for leaks (less than 100 fpm is passing). No requirement to
recertify the altimeter, encoder or transponder.
Mike F.
TSA requirement of Security Awareness Training dancingstar Piloting 3 October 5th 04 02:17 AM
pitot heat question K. Ari Krupnikov Instrument Flight Rules 7 December 11th 03 01:51 AM
Pitot heat Paul Mennen Owning 10 November 6th 03 09:54 AM
Pitot heat Paul Mennen Piloting 10 November 6th 03 09:54 AM
