BGBW Approach
Old April 21st 04, 07:56 PM
gwengler
Default BGBW Approach
Anyone know how *exactly* the missed approach works at BGBW:
http://www.slv.dk/Dokumenter/dscgi/d...B_DME_07-1.pdf
Assuming your airplane can climb with a climb gradient of 6%, where
and when can you descend to 1500 (note the table at the bottom) and
where is your MAP in this case (note the beginning of the dashed
missed approach course line beginning at the runway threshold in the
plan view).
Gerd
Old April 22nd 04, 02:19 AM
Bob Moore wrote:
Seems to me that the MAP would be at 3.5 DME at 1500'. The dashed line
actually starts at that point but is not obvious because the solid track
line over-lays the dashed line. The first part of the missed approach
procedure is a climb straight ahead from 1500' to cross the end of the
runway at or near 2400'.
Why would you argue with the state's official AIP IAP chart? It says "MApt
DME NQ 4 NM" and that is what it means, not what you might like to change it
to.
Old April 22nd 04, 02:17 AM
plan view).
Gerd
Whether you're using straight-in minimums of 1,800 (4% MAP CG) or 1,500 (6% MAP CG)
you descend to either one of those OCAs (ICAO-speak for MDA) once you pass NQ 5.0
DME.
The MAP for either straight-in 1800 or 1500 is at NQ 4.0 DME.
With circling they don't show a climb gradient because all bets are off in
PANS-OPS-land if you have to miss during a circle-to-land maneuver.
Old April 22nd 04, 10:09 AM
I've posted the Jeppesen charts for that procedure on alt.binaries.pictures.aviation
in both PDF and JPEF formats. The Jeppesen version is two charts, the second being
for minimums for this IAP and others for the airport.
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 03:27 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 11:13 AM
Why an NDB approach with a miss to an intersection? Ben Jackson Instrument Flight Rules 10 March 25th 04 03:53 AM
Changes to Aircraft Approach Categories?! skyliner Instrument Flight Rules 10 February 9th 04 08:55 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
