If you are a pilot who uses both a headset and eyeglasses, what IFR
trainng device works and fits best for you? The generic foggles, like Sporty's sells? The Jeppesen JeppShades Flip-Up hood? A particular model of hood? |
I just got a hoodlamb, it's pretty good so far. I've only worn it
for a couple hours though. http://www.mypilotstore.com/MyPilotStore/sep/1482 Jeff Saylor wrote in : If you are a pilot who uses both a headset and eyeglasses, what IFR trainng device works and fits best for you? The generic foggles, like Sporty's sells? The Jeppesen JeppShades Flip-Up hood? A particular model of hood? |
If you are a pilot who uses both a headset and eyeglasses, what IFR trainng device works and fits best for you? The generic foggles, like Sporty's sells? The Jeppesen JeppShades Flip-Up hood? A particular model of hood? I use a flip-up device that clips on my glasses, I can't remember where I got it or the brand. It's lightweight plastic, black, wraparound. They look like Overcasters, now that I've looked at some pictures on a few sites. I've thought about the flip-up foggles that clip on glasses, but what I have works, and is very, very light, which is important. You don't want a lot of weight hanging in front of your glasses for hours, and they're very easy to flip up and down for transitioning to and from instruments. -- Regards, Stan |
I tried foggles, but decided they let in too much peripheral vision. I also
tried something called a "Francis IFR hood" that a CFII had during a stage check. It was bad because it pressed my glasses into the bridge of my nose and gave me a headache. In the end I settled on a tradition hood and it worked just fine for all my IFR training. "Jeff Saylor" wrote in message ... If you are a pilot who uses both a headset and eyeglasses, what IFR trainng device works and fits best for you? The generic foggles, like Sporty's sells? The Jeppesen JeppShades Flip-Up hood? A particular model of hood? |
Foggles did ok for me after I applied a liberal amount of Scotch(tm) tape
to block out the areas I wasn't supposed to see. To me, foggles do a nice job of transmitting a bit of shadow as one might get in light IMC without totally giving away which way is up. However, they do have way too much clear vision area. You'll need to tape over the areas you feel are allowing you to "cheat". --Don Brenor Brophy wrote: I tried foggles, but decided they let in too much peripheral vision. I also tried something called a "Francis IFR hood" that a CFII had during a stage check. It was bad because it pressed my glasses into the bridge of my nose and gave me a headache. In the end I settled on a tradition hood and it worked just fine for all my IFR training. "Jeff Saylor" wrote in message ... If you are a pilot who uses both a headset and eyeglasses, what IFR trainng device works and fits best for you? The generic foggles, like Sporty's sells? The Jeppesen JeppShades Flip-Up hood? A particular model of hood? |
Jeff,
ASA's clip-on for glasses. -- Thomas Borchert (EDDH) |
Jeff Saylor wrote:
If you are a pilot who uses both a headset and eyeglasses, what IFR trainng device works and fits best for you? The generic foggles, like Sporty's sells? The Jeppesen JeppShades Flip-Up hood? A particular model of hood? I used the ones that clip onto your glasses and can be flipped up and down. They aren't a hood, just glasses clip-ons that have part of the "lens" frosted. The only downside is they don't completely block your peripheral vision and once the clear part of the lens gets scratched, they can be hard to see through. However, mine didn't get bad until after several years of use. Matt |
I used the hoodlamb extensively during my training and loved them.
Unfortunately, they attach to your headset, and may not fit onto some of the newer ANR units. Jeff Saylor wrote: If you are a pilot who uses both a headset and eyeglasses, what IFR trainng device works and fits best for you? The generic foggles, like Sporty's sells? The Jeppesen JeppShades Flip-Up hood? A particular model of hood? -- Remove "2PLANES" to reply. |
I bought a Hoodlamb with high expectations. A friend of mine has it and
loves it. However, it would not stay on my David Clark H10-13.4 headset. Just be sure. Rod "Dan Truesdell" wrote in message ... I used the hoodlamb extensively during my training and loved them. Unfortunately, they attach to your headset, and may not fit onto some of the newer ANR units. Jeff Saylor wrote: If you are a pilot who uses both a headset and eyeglasses, what IFR trainng device works and fits best for you? The generic foggles, like Sporty's sells? The Jeppesen JeppShades Flip-Up hood? A particular model of hood? -- Remove "2PLANES" to reply. |
This may sound silly, but I take a $0.99 pair of clear protective
goggles (from Sears or Home Depot, or wherever), then put duct tape over the top half of the lenses, and along the sides. I got tired of losing $20 foggles. I wear glasses and a headset, and these protective goggles are usually quite flexible and comfortable, and work as well as any foggles or view-limiting devices I have used. I can see the panel fine, but nothing over the top, unless I actually try to cheat (which I could do with most other goggles.I used these on a checkride, and the DE had no problem with them. These typially fold up quite well and fit fine in my flight bag, and if I lose them, it hurts a lot less than losing a $20 pair. ![]() Cheers, Cap Jeff Saylor wrote in message ... If you are a pilot who uses both a headset and eyeglasses, what IFR trainng device works and fits best for you? The generic foggles, like Sporty's sells? The Jeppesen JeppShades Flip-Up hood? A particular model of hood? |
Lightspeed with Foggles question | Rod Madsen | Instrument Flight Rules | 19 | August 22nd 03 03:50 AM |
