Effects of CG on cruise speed
Old August 2nd 06, 05:26 PM posted to rec.aviation.piloting
gman
Default Effects of CG on cruise speed
Hello All,
Does anyone know if the location of the CG effects the cruise speed in
something like a Skyhawk of Skylane? In other words, given the same
weight, will the cruise speed at 75% power be higher or lower if the CG
is moved from near its forward limit towards its aft limit.
I think the aft CG will result in a higher cruise speed because the arm
between the center of lift and CG will be reduced (assuming CL is
behind the CG) and the tail will have to do less work.
Any ideas?
Old August 2nd 06, 05:31 PM posted to rec.aviation.piloting
Bob Gardner
Higher. Moving weight aft means that the download on the horizontal
stabilizer is reduced.. Less elevator deflection means less drag.
Bob Gardner
"gman" wrote in message
Hello All,
Any ideas?
Old August 2nd 06, 06:19 PM posted to rec.aviation.piloting
Maule Driver
Yep. And you'll know you went too far back when 1) you've exceeded the
CG range in the POH and 2) when the a/c gets uncomfortably squirrly in
all axis or axii or whatever.
....seeking the middle of the range keeps things comfortable and allows
for some shifting, weighing errors, and such.
Bob Gardner
Hello All,
Any ideas?
Old August 2nd 06, 07:35 PM posted to rec.aviation.piloting
The Visitor
Don't forget fuel burn. But does anybody know how much faster if you do
load it farther aft?
Old August 2nd 06, 09:31 PM posted to rec.aviation.piloting
Bob Gardner
Was it really necessary for me to say that the CG should be kept within the
operating envelope? Are newgroupies so anal that everything must be spelled
out? The manufacturer provides loading information so that pilots can choose
where they want the CG to be depending on their needs...the OP is obviously
opting for speed, and loading to the aft edge of the envelope is just as
valid as a more central loading.
Bob Gardner
"Maule Driver" wrote in message
m...
Yep. And you'll know you went too far back when 1) you've exceeded the CG
range in the POH and 2) when the a/c gets uncomfortably squirrly in all
...seeking the middle of the range keeps things comfortable and allows for
Bob Gardner
Hello All,
Any ideas?
Old August 2nd 06, 11:16 PM posted to rec.aviation.piloting
Maule Driver
Com'on Bob, Chill.
I almost wrote something like "I just wanted to add my 2 cents to the
ol' sage's answer"
I was just rambling with my thoughts on rearward CGs. Your answer was
accurate and complete as always. Heck, you wrote the book.
Bob Gardner
m...
Bob Gardner
egroups.com...
Hello All,
Any ideas?
Old August 2nd 06, 05:55 PM posted to rec.aviation.piloting
Bob Moore
That's the way we did it in the airline business.
Bob Moore
PanAm (retired)
Old August 2nd 06, 06:57 PM posted to rec.aviation.piloting
Kingfish
Bob Moore
PanAm (retired)
Heh. "This is the captain speaking - would all fat *******s please take
up the empty seats in the back of the plane, please...Your cooperation
is greatly appreciated"
Old August 2nd 06, 11:40 PM posted to rec.aviation.piloting
Jose[_1_]
Fat ******* #1: I'll do it for $300. How much is fuel per gallon?
Jose
The monkey turns the crank and thinks he's making the music.
Old August 2nd 06, 07:28 PM posted to rec.aviation.piloting
B A R R Y[_1_]
I would think the CG that requires the least amount of trim would be the
most efficient. If that is in fact true, the most efficient CG would
vary for different aircraft.
Warrior cruise RPM settings lardsoup Piloting 35 October 9th 05 11:59 PM
Crosswind Landings... But airspeed? Jmarc99 Soaring 21 October 4th 05 07:54 PM
Flying on the step? [email protected] Piloting 30 November 3rd 04 01:06 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
