'Problem' with Antares 20m?
Old August 4th 06, 05:43 PM posted to rec.aviation.soaring
Ray Lovinggood
Default 'Problem' with Antares 20m?
From the following webpage:
http://www.aerokurier.rotor.com/akNachr/aeNewsE.htm
Antares too quiet
Lange Flugzeugbau faces an unusual hurdle with the
type certification of its electric glider, Antares.
The required noise level measurement according to Chapter
X was not possible. The noise emissions from the 20-meter
self-launching glider are so low that it can't be heard
above the ambient sound of the surrounding environment.
But the measurements are mandatory for the EASA certification.
Even a modified measuring process failed to produce
data that could be converted to values suitable for
compliance with Chapter X. It has simply never happened
befo An aircraft that is actually too quiet.
Old August 4th 06, 06:18 PM posted to rec.aviation.soaring
Stefan
You can read the full story he
http://www.lange-flugzeugbau.com/htm...asurement.html
BTW, the Antares has received EAS certification on the 14th of July.
Stefan
Old August 4th 06, 06:35 PM posted to rec.aviation.soaring
Greg Arnold
Antares too quiet
I wonder if it makes enough noise for engine operation to be recorded by
the ENL function of a flight recorder.
Old August 4th 06, 08:03 PM posted to rec.aviation.soaring
Andor Holtsmark
The original story: http://lange-flugzeugbau.com/htm/english/news/
noise_measurement.html
(Note our brand new homepage. Much more info in it
now)
to be recorded by
Due to the RPM of the engine, the LE42 propulsion system
produses most of its noise on exactly the same frequence
which flight recorders pick up. There is no problem
recognizing powered flight.
cheers,
Andor
Heater problem fixed! Jim Burns Owning 14 December 17th 04 10:38 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Owning 77 December 3rd 03 09:10 PM
Help with serious Glider Registration Problem Soaring 5 November 12th 03 04:01 PM
EGT Problem Dennis O'Connor Owning 4 August 27th 03 04:25 PM
Problem: Ground Speed Estimate with Volkslogger and WinPilot RamyYanetz Soaring 3 August 26th 03 03:06 PM
