Pawnee Spar inspecitons - where to go?
Old August 29th 06, 02:46 AM posted to rec.aviation.soaring
Default Pawnee Spar inspecitons - where to go?
The Piper PA -25 -235 requires a inspection of the wing spar/cluster
every 24 months.
Who has experience and does these in the Southwest US, Nevada or
California?
Thanks in advance for any steerage or names and phone numbers.
Karen
(Remove "nospam" from the return address to reply)
Old August 29th 06, 04:05 PM posted to rec.aviation.soaring
Any qualified shop should be able to do this for you. The spar
inspection is not unique to the Pawnee, and aircraft such as the Cub,
Maule, etc all have an inspection requirement unless sealed struts have
been installed.
To date Philadelphia Glider Council has had no problems with our
Pawnee's spars--but we do hangar it.
Good Luck--
Skip Guimond
Old August 30th 06, 06:01 AM posted to rec.aviation.soaring
BTIZ
ours has the STC so we don't need that.. but we still have to pull the wings
every 6 or 8 years.. I forget right now.. Johnson Aircraft in Fresno CA (?)
carried Pawnee parts.. I'd check with them,.
BT
" wrote in message
every 24 months.
California?
Karen
basic spar construction Dave Schneider Home Built 29 December 30th 04 02:07 PM
Spar workshop CD and DVD available mat Redsell Soaring 0 May 6th 04 03:52 PM
Marske spar workshop Marske Flying Wings Restoration 0 October 14th 03 04:54 PM
Marske spar workshop Marske Flying Wings Home Built 0 October 14th 03 04:53 PM
Marske spar workshop Marske Flying Wings Soaring 0 October 14th 03 04:52 PM
