I had a bizarre problem on my KLN94. The display itself is totally
fine (i.e. the moving map shows everything correctly, all pixels are OK); however, on almost all other text pages, there is information missing. For example, the groundspeed is not showing on the NAV page, or a frequency on an APT page. One APT page showed no airport information at all. On some pages, a whole text line is missing, on another just a few numbers (the letters are fine) or visa versa. It continued to work fine to input the autopilot. This has happened twice in the last two years and by shutting the unit off and on the problem went away. Ever heard of anything like that? Gerd |
gwengler wrote:
I had a bizarre problem on my KLN94. The display itself is totally fine (i.e. the moving map shows everything correctly, all pixels are OK); however, on almost all other text pages, there is information missing. For example, the groundspeed is not showing on the NAV page, or a frequency on an APT page. One APT page showed no airport information at all. On some pages, a whole text line is missing, on another just a few numbers (the letters are fine) or visa versa. It continued to work fine to input the autopilot. This has happened twice in the last two years and by shutting the unit off and on the problem went away. Ever heard of anything like that? Gerd Nope.. I've got an intermittent horizontal row of pixels on my 89B.. but thats about it. Good luck Dave |
That sounds like a software problem take it to your dealer or a
reputable honeywell dealer. It will probably have to be removed and re programmed and maybe sent back to the factory. I am by no means a avionics wiz but I have a bunch of time dealing with them and with these gps units. Great unit to by the way. matt tiberii com asel amel ases cfi cfii gwengler wrote: I had a bizarre problem on my KLN94. The display itself is totally fine (i.e. the moving map shows everything correctly, all pixels are OK); however, on almost all other text pages, there is information missing. For example, the groundspeed is not showing on the NAV page, or a frequency on an APT page. One APT page showed no airport information at all. On some pages, a whole text line is missing, on another just a few numbers (the letters are fine) or visa versa. It continued to work fine to input the autopilot. This has happened twice in the last two years and by shutting the unit off and on the problem went away. Ever heard of anything like that? Gerd |
Unusual Honeywell KLN94 aviation GPS failure - what could causethis? | Dave S | General Aviation | 6 | September 12th 06 05:32 PM |
Unusual Honeywell KLN94 aviation GPS failure - what could causethis? | Dave S | Instrument Flight Rules | 5 | September 12th 06 05:32 PM |
The BIGGER problem in the FAA exposed | JohnWayne | Instrument Flight Rules | 4 | September 2nd 06 11:21 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
Problem: Ground Speed Estimate with Volkslogger and WinPilot | RamyYanetz | Soaring | 3 | August 26th 03 03:06 PM |
