Question for LS-1f folks...
Old October 22nd 06, 01:59 PM posted to rec.aviation.soaring
Gary Emerson[_1_]
Default Question for LS-1f folks...
I'm aware of an LS-1f that has some wear both on the pins in the wing
root and the holes in the fuselage which carry the load from the wings
to the fuse. Does anyone out there have personal experience with
getting this fixed on an LS-1f. If so, please let me know.
Gary
For what it's worth, the recepticals in the fuse definitely do not look
like they were designed in a way that could be replaced without some
major cutting/welding. The pins in the wing root also do not strike me
as being replaceable without cutting them out of the glass.
I want to ask you the most important question of your life. Douglas Olson Owning 1 May 22nd 05 05:15 AM
182RG question Paul Anton Owning 11 May 16th 05 09:45 PM
