Baby, It's Cold Outside!
Old January 31st 07, 11:38 PM posted to rec.aviation.piloting
Jay Honeck
Default Baby, It's Cold Outside!
Mary and I went flying this morning, just a quick burger flight to
nearby Muscatine, Iowa, to warm up the oil and keep sharp. The
temperatures have been hovering around zero for the last several days,
so although the engine was nice and toasty (thanks to Tanis oil pan
and cylinder heaters) everything else was completely cold-soaked.
Mary's preflight inspection was thorough, fast, and in the hangar, out
of the wind. All the ice on our taxiway has sublimated away (it sure
hasn't melted!), so pulling Atlas out was much easier, although
everything was completely stiff in the cold. At those temperatures,
nothing moves easily.
Putting on the frozen-solid LightSpeeds was enough to wake me up!
They slowly thawed, up against my head, and softened to the point
where the ANR functioned again, as we taxied out to the active.
Departure was normal "high winter performance climb". Nothing like
cold, thick air to make Atlas into a virtual rocket ship, and Mary
climbed out at an impossibly steep angle, hanging on the prop. We
were at 3000 feet before we left the pattern.
The outside air temperature at 3500 feet was -20 F. Even with the
outstanding Piper heater on full, we didn't get the inside temperature
up to 60 until we were half-way to Muscatine. (It's only a 24 minute
flight...) The sky was a peculiar milky white, but all the reporting
stations were reporting "Clear below 12000 feet" for 100 miles in
every direction. You could see the weather was changing, however, and
snow was predicted to hit later on. (It has been snowing in spits and
spats, as I'm writing this.)
Coming in to land in KMUT, Mary crossed over midfield and entered a
left downwind for Rwy 24. With the wind 190 at 10, gusts to 13, it
was pushing her in a bit, but she expertly carved her way to a perfect
landing on 24.
As she allowed the nose to lower on to the runway, the glareshield
passed through the horizontal -- and kept going down! Apparently the
extreme cold had caused the nose strut seal to fail, and we were
rolling down the runway in an unusual nose-down attitude, the strut
fully collapsed. Nothing alarming, but it sure felt funny.
Plugging Atlas into the handy power cord that every FBO in the Upper
Midwest has deployed at this time of year, the excellent folks at
Carver Aero already had the courtesy van warming up before we even
walked in the door! We usually walk to the nearby "Good Earth"
restaurant, but there was no way were walking today! So, as long as
we had wheels, we drove into town and ate at the outstanding "Button
Factory" -- a terrific restaurant that is inside a fascinating old
button factory. (Muscatine, being right on the Mississippi River, was
once the "button capital of the world", thanks to an easy and ample
supply of clams and clamshells, from which buttons were originally
made.)
After a fantastic meal we shivered our way back to the airport (but
not before topping off the courtesy van). Now my turn to preflight,
the wind had really picked up. The temperatures had cracked the low
teens, now, but the wind still made it feel like a hundred below.
Taxiing out on our deflated nose strut felt funny, but we were soon
rocketing out over the Big River, making a broad circle over what (in
summer) is a national wildlife refuge, packed with birds. Now, it was
nothing but a stark wasteland of interlocking pieces of ice, jammed
together in bizarre and fantastic patterns. It's hard to believe
there is ever a time when making this flight is almost unbearably hot,
but it's true. In July, it would be like sitting in a sauna...
Touching down carefully in a gusty crosswind back in Iowa City, we
taxied slowly back to our hangar. Once tucked safely inside, I put
some down-force on the stabilator while Mary lifted on teh prop, and
we got the nose strut back up a few inches. My A&P mechanic says it
MIGHT be okay, once it warms up, and we add some nitrogen, but will
probably need a new seal. We'll just have to wait and see.
Baby, it's COLD out there!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 1st 07, 12:04 AM posted to rec.aviation.piloting
Jim Macklin
Some warm air under the panel will make the gyros last a
little longer, those bearings need to have lubrication too.
Flat struts are a real problem with some airplanes due to
cold. For example a Bonanza or Baron uses the inflated
strut to keep the wheel positioned in the well. A flat
strut can allow the wheel to move into a position which can
cause it to jam in the wheel well while it is up.
"Jay Honeck" wrote in message
flight to
The
several days,
Tanis oil pan
cold-soaked.
hangar, out
away (it sure
although
temperatures,
me up!
the point
active.
Nothing like
and Mary
prop. We
with the
temperature
a 24 minute
the reporting
miles in
however, and
in spits and
entered a
to 13, it
to a perfect
| landing on 24.
glareshield
Apparently the
we were
the strut
funny.
the Upper
folks at
we even
Earth"
as long as
outstanding "Button
fascinating old
and ample
originally
| made.)
airport (but
preflight,
cracked the low
below.
were soon
over what (in
Now, it was
ice, jammed
believe
unbearably hot,
sauna...
City, we
inside, I put
prop, and
mechanic says it
but will
see.
| Jay Honeck
| Iowa City, IA
| Pathfinder N56993
Old February 1st 07, 12:38 AM posted to rec.aviation.piloting
Dallas
Gosh Jay,
I was just putting some Aloe Vera on my sunburn when I read your post.
Sounds bad up there.
Dallas
Old February 1st 07, 01:08 AM posted to rec.aviation.piloting
Kevin Dunlevy
Red Green (from Possum Lodge up north) and I recommend duct tape over the
exterior of the cabin air vents in winter. I think there is an STC for
this.
I've had lots of nose struts go bad in winter, requiring seals and nitrogen.
Some bottom out and others have excessive unrestrained free travel. It's
good to do soft field landings when it is cold (below 10F).
You know it's been a cold winter when water drips out of the high wings in
the spring from the frozen vapor condensed from the pilot's breath. KD
landing on 24.
made.)
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old February 1st 07, 09:55 PM posted to rec.aviation.piloting
Viperdoc[_4_]
It's supposed to get colder yet this weekend! Just remember to bring your
cell phone, survival kit, epirb, etc. A night out in this weather would get
pretty uncomfortable.
I was planning on doing some backyard camping outside with my 10 year old
son this Saturday, but even with good gear it would be mighty cold. The
latest forecast is for subzero temps with a pretty good wind chill.
Being out on the ramp pushing a plane around isn't much fun under these
conditions, either!
Old February 3rd 07, 02:43 AM posted to rec.aviation.piloting
Al[_2_]
We keep our Cessna 172 engine compartment/oil sump toasty warm with a 75
watt light bult and an arctic insulated nose cover. The oil drips off
the dipstick even below 0F. A small ceramic heater in the cabin during
pre-flight warms up the gyros and (very importantly) the windscreen, to
keep it from fogging up during our taxi to the runway. When I started
it at +2F a couple of weeks ago, I did need to use a couple extra shots
of prime to get enough gas to atomize. Oil pressure came up quickly.
The down side: during my descent into out destination, the cabin heat
diminished substantially. Brrrrr.
Al
1964 Skyhawk
SFF-Spokane, WA
Old February 5th 07, 05:07 PM posted to rec.aviation.piloting
Danny Deger
"Al" wrote in message
watt light bult and an arctic insulated nose cover. The oil drips off the
keep it from fogging up during our taxi to the runway. When I started it
at +2F a couple of weeks ago, I did need to use a couple extra shots of
Al
1964 Skyhawk
SFF-Spokane, WA
To keep my airplane's oil flowing freely in the winter, I moved to Houston
Danny Deger
Old February 5th 07, 11:56 PM posted to rec.aviation.piloting
Roger[_4_]
On Mon, 5 Feb 2007 11:07:45 -0600, "Danny Deger"
Some years back we were on our way home after visiting Joyce's folks
in Florida. When we left it was shorts and short sleeve shirt
weather. We stopped at Gainesville GA to visit my son for a couple of
days and it was downright chilly, but nothing the cabin heater
couldn't handle with ease.
Leaving Gainesville we angled over to Chattanooga and then North for
home. I'd guess it was about 50 to 75 miles north of Chattanooga that
we flew over the front and the temperature started down. Some where
around Kentucky we put our jackets on. By the time we reached Ohio we
had our wool sweaters on under our jackets and by the time we reached
Michigan the winter coats had been dug out of the luggage and the
gloves were on. It was downright cold in there!
At the next annual my mechanic had to have a flame cone replaced in
one of the resonators. As he had to go that far, along with my
complaint about lack of heat, he pulled the muffler and shroud.
Surprise! We found the jacket only had half the normal number of
threaded rods welded in and they were only on the outside with none on
the inside. So said muffler went in for repair as well.
We ended up eliminating the resonators even though they sound nice and
do quiet the exhaust note a bit, but they are heavy. Their weight
causes the rubber bushings in the exhaust supports to fail about every
year or two depending on how much you fly. But the new muffler? What
a difference. You may freeze your butt off while heading down the
taxiway, but once in the air the cabin is shirt sleeve comfortable
even when it's single digits outside. OTOH it 's still jacket time
when it gets any colder than that.
Al
1964 Skyhawk
SFF-Spokane, WA
First sensible fix I've read, other than I think I'd pick some where
other than Houston.:-)) Then again, I can't say much about location
as I live in Michigan.
Danny Deger
www.rogerhalstead.com
Old February 3rd 07, 04:28 AM posted to rec.aviation.piloting
Nathan Young
On 31 Jan 2007 15:38:55 -0800, "Jay Honeck"
I went flying tonight. 15G20 directly down the runway, an OAT of
10degF, and 1/3rd tanks makes for fun takeoff / climb performance.
Takeoff before the displaced threshold ends, and pattern altitude by
the end of the runway.
One thing that strikes me about the cold weather flying. The
reduction in cabin heater temperatures as I throttle back to rejoin
the pattern. The heater in my Cherokee does great at higher RPMs, but
in the winter, 1700RPM apparently does not generate enough exhaust
heat.
-Nathan
Old February 3rd 07, 04:38 AM posted to rec.aviation.piloting
Jay Honeck
heat.
My Warrior used to do that. Once I "weather-sealed" the plane
(filling/closing all the cold air leaks), that went away.
Of course, I kinda like it a bit cooler when I'm coming in to land.
Especially if it's a nice, gusty crosswind...
Jay Honeck
Iowa City, IA
Pathfinder N56993
Baby, it's cold out there! Jay Honeck Piloting 14 February 3rd 07 08:19 PM
Card Model - Bowlus Baby Albatross - Jeff Byard's BA-100 [email protected] Soaring 0 November 24th 06 02:40 AM
Fly Baby Plans Off the Market Ron Wanttaja Home Built 9 June 6th 04 02:45 PM
Battery Replacement and Cold Cranking Amps O. Sami Saydjari Owning 27 February 2nd 04 02:38 PM
