Flight Review in a turbo twin
Old February 16th 07, 02:00 AM posted to rec.aviation.owning
Chad
Default Flight Review in a turbo twin
I own a turbo Cessna 310 and I'm wondering if other turbo twin owners
do their biennial flight review in their aircraft. Is single engine
work required for a flight review if done in a twin? I'm concered
that doing the review in my aircraft may be hard on the engines,
specifically the turbos. Would I be better off to just rent a single
engine for the review?
Old February 16th 07, 02:45 AM posted to rec.aviation.owning
How do you figure flying for an hour will be hard on the engines?
A flight review is not the same as the practical test.
Jim Pennino
Remove .spam.sux to reply.
Old February 16th 07, 02:51 AM posted to rec.aviation.owning
Kyle Boatright
"chad" wrote in message
Explain your concern to the instructor before the flight and make sure he
understands what things you *don't* want done with your engines. Then ask
ask if s/he can give you a flight review without doing any of the things you
consider problematic.
And remember, you are PIC, so you can say "No, I don't want to do that out
of concern for $50,000 of engines.."
If you can't find an instructor who is comfortable with your rules, go ahead
and rent a C-152 or whatever. It'll probably be cheaper than whatever it
really costs you to run that 310 for an hour.
KB
Old February 16th 07, 01:22 PM posted to rec.aviation.owning
Denny
Take your review by getting signed off in a tail dragger... You will
learn more about airplane handling than a hundred hours of pointing
your twin towards the horizon...
denny
Old February 16th 07, 02:35 PM posted to rec.aviation.owning
Nathan Young
The flight portion of my BFRs have focused on basic maneuvers, stalls,
slow flight, steep turns, and landings.
These procedures pretty much dictate the engines will go through many
high/low power cycles... Not the best for a turbo'd engine.
If I was you, I would rent a single for the day.
-Nathan
Old February 16th 07, 02:43 PM posted to rec.aviation.owning
Dan Luke
Pardon the question from an ASEL owner, but what good is a BFR for a ME pilot
that doesn't include engine-out procedures?
Dan
C-172RG at BFM
Old February 16th 07, 03:16 PM posted to rec.aviation.owning
Denny
Dan
C-172RG at BFM
The BFR is non plane specific, non maneuver specific, etc... The CFI
can call for engine out procedures but that is exactly what he does
not want his turbo engines to go through... If he does it in his
plane, then he and the CFI have to decide what specific maneuvers will
be done...
Even though I learned to fly in conventional gear and flew such planes
most of my youth (J3, T-craft, 120, 103, etc.) I have also spent the
past few decades pushing twins towards the horizon... This past BFR I
chose to renew my aquaintance with conventional gear by checking out
in a PA-12... The reason for this one is that it returns me to the
right hand stick, left hand throttle, world.. First ten minutes were
fun breaking my right hand from moving when my brain called for power
changes... By the end of the sessionI had the full stall landing
working again and the hands sorted out... More fun that a bag full of
monkeys... Gonna do it for the next BFR also...
Old February 16th 07, 03:35 PM posted to rec.aviation.owning
-Nathan
My last review focused on communications (center, tower, ground),
airport area procedures, efficient use of the radios, using proper
phraseology, etc.
All the CFI's I know will pretty much do whatever you suggest you
feel you could use some brush up on. There is no requirement to do
basic maneuvers.
If you are instrument rated, is there some procedure you are less than
100% at?
If you are not instrument rated, when was the last time you did some
hood time?
Jim Pennino
Old February 16th 07, 03:38 PM posted to rec.aviation.owning
Dan Luke
pilot
be done...
changes... By the end of the session I had the full stall landing
Sounds like fun.
I guess it's ok if you can say for sure your engine-out skills are sharp. A
couple of my ME pilot acquaintances of mine couldn't truthfully make that
statement.
Dan
C-172RG at BFM
Old February 16th 07, 04:09 PM posted to rec.aviation.owning
Robert M. Gary
As a CFI I would not sign a guy off in a single for a BFR if I know
his daily flying is a turbo twin. However, we could probably do the
flight review in the twin without putting too much stress on his
engines. Or, he could rent a twin.
-Robert, CFII
Online Flight Review Course john smith Piloting 1 May 29th 06 02:02 AM
Electronic review of flight? Al Instrument Flight Rules 19 December 30th 05 09:51 PM
Turbo performance vs non-turbo John Doe Owning 22 October 8th 05 02:34 AM
Non-TW CFI cannot give Flight Review in TW Hilton Piloting 12 January 19th 04 10:31 PM
Converting engine from Turbo to non-Turbo Dick Kurtz Home Built 7 October 31st 03 04:48 PM
